Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Unable to connect Laptop to Mitsubishi Projection TV
I am trying to connect my laptop to my Mitsubishi projection tv with a VGA to RGB Component cable, but there's no picture.
Also when i connect my room mates old laptop with an S-Video to component cable , it works. Is there a problem with my TV, laptop or resolution. I have treid changing resolution of my laptop but there's still no picture.
My laptop is a high definitaion laptop with resolution of 1600X900 and my tv is also high definitaion so will i be able to view my desktop on tv in high resolution ?
  • Brett Duxbury
    Brett Duxbury May 08, 2017
    Hi totalsiddhar, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    Did you switch the Windows output to mirror the laptop screen ?
    It will be a function key it varies on each laptop model mine is F4 it could be a different key.
  • 154 Answers
SOURCE: Everything has a green tint when upgraded to HD 1080.
i think you are connecting to wrong jacks
Posted on May 23, 2008
SOURCE: Connecting DELL Laptop to Mitsubishi WS-65869 Projection HDTV purchased in 2001
for the ps3 just buy a component cable for it and match up the colors
Posted on Aug 11, 2008
  • 18 Answers
SOURCE: hook up a lg blueray player to mitsubishi medallion 65"
Yes, there is an adapter which will take the hdmi output of the blue-ray and convert it to dvi. You will also need to connect the blue-ray audio out (rca jacks) since the hdmi is both audio and video (digital) and the dvi is video only.
Posted on Jan 04, 2009
  • 67 Answers
SOURCE: No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Posted on Jan 07, 2009
jan mczeal
  • 632 Answers
SOURCE: how to get laptop connected with vga connector to
Unplug the television. Connect the VGA compatible monitor cable from the laptop's VGA monitor Output to the VGA Input on the back panel of the television. You will need a splitter to connect the audio cable from your laptop to the VGA Audio Input on the television. Never mind if you have speakers connected to your computer.
Press the Device button on the remote control or on the television front panel to display the Device Selection Menu. Select the device you want to view, in this case VGA. The only compatible resolution is 640X480 at a sync rate of 60 Hz.
Do not leave stationary or letter-box images on-screen for extended period of time to avoid uneven picture tube aging.
Posted on Jan 23, 2010
Trying to connect Laptop VGA to TV Component (RGBHV) INPUT
Computer VGA to TV AV RCA S-Video Composite Converter, Costech HD 1080P HDTV Video Cable Converter Adapter Plug and Play for HDTVS, Monitors, Display, Laptop, Desktop, PC
Go to Amazon and for $10 solve the problem
Feb 04, 2018 | Mitsubishi Televison & Video
How do i change my resolution to 720p on 55" inch older mitsubishi tv
Are you sure the TV supports 720p? Many older 55" RPTVs are 480 only. Even with Component. Most older component is only 480
Feb 25, 2015 | Mitsubishi WD Televison & Video
How do i connect my dvi to vga to my misubishi ws-65313
you can't, DVI is a digital video source and VGA is an analog video source. however there is a VGA to component RGBHV cable that you can use. the Mitsubishi TV is very limited to the resolutions the VGA output can be. only 1080I, 480P or 480I. HD component video input in the menu you must change the source from Y /Pb/ Pr to RGB.
Jun 07, 2014 | Mitsubishi WS-65313 65" Rear Projection...
Rgb connection stopped working on laptop
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
I am trying to connect my laptop via VGA cord to my 65" Mitsubishi Medallion, but when I click on the VGA device selection in the device menu, it goes to a blue screen and says "Warning: Turn on...
Press the Windows key + P on your laptop.
Or, if that doesn't work, look on your F keys for something that looks similar to a monitor.
Press the FN key and that key.
This should bring up your laptop's display on the tv.
Mar 09, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Connect laptop to toshiba 50h8250
This requires a converter. If the laptop has a VGA port, use an VGA to component video or VGA to composite video converter. See this site for some examples: . Do not use a VGA to component video cable - these are meant for projectors that use RGB signals.
If the laptop has an HDMI port, you'll need a different type of converter, like this: . Then set the output to YPbPr.
I hope this helps.
(I doubt your laptop has a video controller that can output a non-RGB signal.)
Nov 14, 2010 | Toshiba 50H82 50" Rear Projection...
Cant connect VGA form laptop to TV.
Sounds like you may be trying to use a resolution or scan rate the TV does not support. Many of these televisions do not support 720p, but DO support 1080i.
Good luck.
Mar 02, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Upgraded DirectTV satelite TO HD
direct tv hd receiver is hdmi or rgb which is a different signal than the rgbhv input on the back of older mitsubishi tv . You can buy a converter that converts the format for about 90 dollars online. It converts rgb or component to vga/rgbhv
Oct 24, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
1,044 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
