Question about Symbol Cobra LS 1902 (LS1902TI0000100D) Handheld
Need manual to setup bar code scanning
Need manual to setup Symbol LS 1902t-1000 hand scanner
  • Ranny Dale Chadwick May 01, 2009
    Thanks for info, I have downloaded info but scanner is bad
  • 97 Answers
  • Oscar Suarez
    Oscar Suarez May 01, 2009
    can you give me more information? What is the problem with the scanner?
Cannot read bar code
If it will not read any bar codes, then it must be repaired. If it only reads selective bar codes, then perhaps the one you are trying to scan may not be of the type it recognizes.
This scanner will read the following codes: LS 1004/LS 1006: UPC/EAN, Code 39 full ASC11, Code 128, Code 93,
Codabar, Interleaved 2 of 5, Discrete 2 of 5; LS 1000: undecoded
Mar 09, 2015 | Symbol LS-1006 (ls1006i0001900z) Handheld
I'm using Symbol LS1004 with SirsiDynix Symphony 3.3.1 Workflows. How can I tab over after each scan, without having to hit <Enter>? Thanks, -john
Here is what I did to fix the problem of the bar-code scanner not going to next line after a successful scan. (Symbol ls4000i,This fix should work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
https://docs.symbol.com/manuals/3789802a.pdf
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning! If you set scanner to default, you need to be aware of which bar-code types you use. (We use UPC-A) Also if you have it programed for other things already you may not want to set all settings to default. You can skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5. The Suffix you want to add to fix this particular problem is ENTER. So that it goes to the next line. There is a prefix/suffix value chart on page 162 table A-4. The code for ENTER Is 7013. In order to enter this code you will need to print off the Numeric Bar Codes found in section 5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
YOUR DONE !
Your scanner should be working now. Also look through the manual there are some nice functions that can be turned on and off with a simple bar code scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
Apr 06, 2011 | Symbol Spark LS 1004
Having to hit enter after scanning an item
You would need to setup those three scanners correctly, the solution is described on the manufacturers website, please see http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=ADC-01244&sliceId=SAL_Public&dialogID=189660762&stateId=1%200%20189654426
Jun 29, 2010 | Symbol LS 2208 Barcode Scanner
I HAVE THE SYMBOL LS 1902T SCANNER. IS WORK IN
Yes, it will work. The scanner interfaces like USB and RS232 are Operation System independent.
Jun 20, 2010 | Cobra Symbol LS 1900 (SYMLS1902T3000S)
Symbol LS 9100 does not transmit data
after scanning the defaults barcode you just scan the "Enable LS 9100 Communication" on this manual on the link above.https://docs.symbol.com/manuals/1536503c.pdf
May 11, 2010 | Symbol LS9100 Hands Free
Manual carriage return necessary after scanning barcode
With the Symbol scanners, they usually come with a sheet at least of scan codes to configure the scanner. One of those bar codes will have the option of not needing to manually hit the carriage return. What model scanners are they? You can probably find the codes from Symbol.
Sep 17, 2009 | Symbol LS 2208 Barcode Scanner
Symbol ls 1902t-1000
You need to set up the scanner -- if you don't have a manual, you can download one from http://support.symbol.com/support/supportcentral/supportcentral.do?id=m1 Then, call Symbol Support at 1-800-653-5350 and they'll talk you through it.
Cheers
Billy Barcode
Jul 18, 2009 | Symbol Open Box Cobra LS 1902T...
Symbol Cobra LS 1902 (LS1902TI0000100D) Handheld Logo
398 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
