Question about Acer Aspire One PC Notebook
"Like not enough power"
After half month using this netbook, suddenly it become slow...the screen dim n bright jz like insufficient power...even my mouse wont move smoothly. no matter i use battery or outlet power, its still the same. i really dont know how to show it to the acer technician since it will become like this sudenly n unexpected time...
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
I have a CrystalView XT Android Tablet/Netbook. My son tried to dim the brightness on the screen and ended up darkening it out all the way. How can I fix this through the keyboard? As I can't s
i have the same tablet/net-book and also accidentally lowered the brightness past 4/10 of full brightness setting. I couldn't see anything on screen. I found that if i put a bright flashlight to/on the screen, I could see what was on screen, it was dim, but not off. I used this technique to maneuver my way to the settings, display, brightness, and turn up the brightness to where I could see it. I hope this info didn't come too late. WebRepOverall ratingThis site has no rating(not enough votes)
Nov 24, 2012 | Computers & Internet
Asus Eee PC 1215n half screen on the right is white, the other half is fine
The LCD screen in your laptop is defective, the only option is to replace. Go to www.ebay.com Type: make and model of laptop, refine search to screen.
May 23, 2012 | ASUS Eee PC Seashell 1215N-PU17-RD...
How do i reset to factory settings?
hi
make sure the AC adapter is plugged in to the netbook and into an wall outlet that works . the dim indication tells me that there is power diminishing while the ipod takes more power from your computer .
Feb 05, 2012 | Acer Aspire One D260 Netbook
I have an LG Flatron L1530S monitor. It had been working perfectly fine. However, since a month, when I used to switch it on, the screen would come on, and then become very dim, though the display would be...
More likely to have dying power supply due to bad DC filter caps as you can see in my albums here:
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Failed LG: http://s807.photobucket.com/albums/yy352/budm/LG/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Aug 02, 2011 | LG Flatron L1512S 15" LCD Monitor
Re: DeWalt 18V XRP Cordless Drill Driver. Should performance of the drill slow as battery becomes weaker? My drill works fine for quite some time then suddenly loses all power, even the light won't...
Yes. It's kind of like a flashlight when your batteries get low the light get dim, but if you replace the batteries light gets bright again. The drill will get weak as battery get low.
May 09, 2011 | Garden
Screen very dim ..how do i turn up the contrast /brightness
Hello !
Test with an external monitor. If it works, there is a problem with the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Hope this helps.
May 08, 2010 | Computers & Internet
Cant turn the brightness down on my asus netbook
You should be able to use the "FN" key and "F5" key, press and hold the "Fn" key then while holding that key, press the "F5" key to decrease the brightness. Use the same(Fn) key and "F6" to increase the brightness.
Jan 02, 2010 | ASUS Eee 4G Notebook
My Garmin nuvi 1300 brightness problems
I spoke to Garmin Support about this issue. There are 2 settings for contrast on the nuvi 1300. You need to set the contrast while it is plugged into the vehicle, and also while it is unplugged from the vehicle. The reason for the 2 settings is to save the charge of the battery while it is not plugged into the vehicle or power source.
Sep 14, 2009 | Garmin nuvi 1300 Car GPS Receiver
Horizontal lines appear in newly saved images
the only thing i can think of is the sensor being misconnected or kaput. are you viewing them on the camera screen or a pc? it could also be camara screen...
Jul 05, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Acer Aspire One  PC Notebook Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
