Question about John Deere Garden
John deere 2010 gear shifter hung up in neutral
  • 140 Answers
Check clutch linkage to see of anything is binding up. If there is a bad bushing it could throw the alignment out.
Posted on May 19, 2014
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
pic498
  • 32 Answers
SOURCE: 1987 john deere 750 compact tractor 4 wheel drive, wont start
percussive maintenance my friend. Try banging on the solenoid and starter with a hammer while in the start position. Also, if you have a voltmeter, you can see where voltage is getting to and that will help you as well.
Posted on Jun 13, 2009
rwvanlue
  • 486 Answers
SOURCE: I need to know where to add hydraulic fluid in a
... should be between operators seat and 3rd link arm. A large nut/cap on top of the transmission cover, near the rockshaft of the 3-point hitch arms.
Posted on Nov 08, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere 2010 utility tractor, lights come on
1) Battery condition and clean cable connections
2) Check the voltage & connections at the solenoid
*Is full battery voltage found at the solenoid?
3) Does the small wire that activates the solenoid from the ignition switch/safety switches have voltage when the key is in the start position
a) voltage yes, but it does not start; suspect solenoid
b) voltage no, inspect and check all safety switches for voltage to and from each switch
c) safety switches do NOT have voltage to them: inspect connections on ignition switch and check for voltage coming into the switch from the battery.
Posted on Nov 10, 2009
nova2nv
  • 197 Answers
SOURCE: where is the neutral safety switch on a john deere
Its located on left side of trans,just under the shifter lever
Posted on Nov 14, 2009
My John Deere ride on mower appears to be stuck on gear when I move the gear stick to neutral still the same stuck in gear. Can you help please?
Dear Susan,
Someone will be needing to get the machine up in the air, or at least high enough to get under it and look, and see what is going on.
You may have some linkage bent, or a joint has come apart, or a belt has broken, or whatever.
It is pretty unlikely the problem is bad, but surely needs to be diagnosed.
The person will probably begin by removing the shifter linkage and seeing if the transmission will work properly whilst disconnected to the shifter.
It should.
God bless your efforts.
Jul 11, 2016 | John Deere Garden
Keeps going into neutral popping in an out of gear
Hi Frank:
I'd start by checking the linkage for excessive wear. There will probably be a cam or spring loaded device that keeps the shifter linkage in the correct position. Sometimes an accumulation of contaminated grease/dirt can prevent the proper function.
Jul 01, 2015 | John Deere 310sj Backhoe
Transmission shifter hung up in netural
Expose the shifter mechanism from the base, look to see it the is an obstruction that is causing the shifter not to shift... Pay attention to the shifter mechanism ends and see if it's worn out, they sell both OEM and aftermarket shifter arms and linkages..
Oct 11, 2013 | John Deere 420,1020,2010,2020,2510,2520...
MY SONS JOHN DEER GPX WILL GO INTO REVERSE BUT NOT FORWARD TOOK THE GEAR BOX APART AND LOOKED AT THE WIRES WHICH ARE ALL CONNECTED WHAT SHOULD I DO
check out the shifter switch and make sure that all of the wires are connected, you could also try switching the polarity on the motors and make sure that the gearboxes are not hung up
Apr 25, 2011 | Peg Perego John Deere Gator HPX Ride on...
The John Deere will go in reverse but will not move when in 1st or 2nd gear.
probably a bad/disconnected shifter switch first of all check to make sure that the shifter switch is connected underneath, you can order a new one here www.powerwheelsoutlet.com
Sep 04, 2010 | Peg Perego John Deere Gator HPX Ride on...
John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
May 21, 2009 | Peg Perego John Deere Gator HPX Ride on...
Garden Logo
52 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
