Beko tv model nr17wlb450s...it's on standby but can't get it switched on manually as remote has packed up (& yes I have tried changing the batteries & turning the tv on & off from the mains!!) Does anyone know how to do this?
nfandres
  • 168 Answers
SOURCE: Sony Vega Digital TV model KD-28DX50 U
the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, vif,sif, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service technician
Posted on Jan 16, 2007
SOURCE: wont come on
try pressing one of the number keys instead of the power button on the remote
Posted on Oct 25, 2007
SOURCE: Durabrand tv won't work with vcr/dvd player
I was given a dwt1905 tv for my kids without a remote so they would have a tv for there dvd player and games plus cable comes to find out I was not able to control anything I listed above with my cable remote because there is no codes you have to buy the remote from the company I called 3# before I was able to find out anything about a remote the contacted # is 1-800-242-7158 and the cost was 19.99 for a new remote that is the only way you will be able to work the tv with dvd player,game systems and cable I hope this helps........ good luck
Posted on Oct 17, 2008
shbuckler
  • 126 Answers
SOURCE: tv wont turn on standby light flashing
seems like an error code (the flashing)
I would say if there is an error code it need to be taken for repair
Posted on Dec 25, 2008
SOURCE: Sony TV Trinitron is on standby
standby light flashes tv wont turn on
Posted on Jun 01, 2009
Polaroid TLX-01511C LCD TV REMOTE WONT WORK
Change battery and see. Look for any jammed buttons on the remote and/or on the control panel of TV. If you have removed the plug, when the TV was in standby mode, sometimes the system controller could not have got time to reset. Try using the control panel buttons and see whether the TV responds. If not, switch it off manually, switch off power and remove plug and retry after 48 hours.
Aug 21, 2012 | Polaroid TLX-01511C LCD TV
Looking for a sky remote control code for beko.
Hello
The three digit Sky remote code for Beco TV are:
514 398 065
Four digit code is:
0125
1* Turn your TV and SkyHD box on and press tv on your remote control.
2* Hold down select and the red button together until the red light on your remote
control blinks twice (this is after about two seconds).
3* Press tv again.
4* Key in your TV's brand code. The light on your remote control blinks twice.
5* Press standby on your remote control.
If your TV switches off, press select.
The light on your remote control should blink twice.
If your TV does not switch off, press tv, then press standby.
Repeat the sequence of pressing tv then standby until the TV switches off,
then press select.
If the light blinks three times, your remote control has checked all the possible
settings for the code you used. Check you have the right code and start again
at step 1.
*6 Turn your TV back on and press the tv guide button on your remote control.
The TV Guide screen appears, meaning the remote control settings have
been reset.
Aug 12, 2011 | Televison & Video
I need beko tv code for matsui URC 11-4241 all for one remote
One For All 5 Digit Codes for Beko TVs.11314,23341,22413,11322,
23313,31341
One For All 4 Digit Codes for Beko TVs. 0714,0035,0486,0370,0037,0418,
0556,0606,0715,0808
also try try 0514 (for v) or 0398,0065
If none of the above work, let me know, I assume you have the instruction book for the remote so you know how to enter the codes. Let me know how this works out.
Benjamin
Nov 18, 2009 | Televison & Video
32" beko TV stuck in standby
Ur power board is dead.U need a new one.
Jun 21, 2009 | Beko 324250WN 28" TV
Wont come on
Instead of just unplugging the TV, perform a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If the TV still won't turn on, then it appears something is wrong with it's mainboard since the TV is still receiving power because the standby light is still coming on.  The cost of fixing an older TV's mainboard could be costly or impossible if the part is discontinued.
Mar 25, 2009 | Beko 324250WN 28" TV
TV Remote not working.
Philips
0081
584,065,040,041,582,221,115,071,351,402
Try these i acnt find one for your model but sometimes others for the same make might work
Let me know,plz
JonnieC
Jan 20, 2009 | Philips Magnavox 27MS343S 27" TV
SHARP 29" TV switching off to Standby
have you tried changing the batteries just to elimate this problem
change them
sometimes if the batteries are low in electronic devies, they send a wek signal to its receiver (your tv),
your tv gets confused and then switches itself to standby
if you have changed the batteries and this problem still persists
it can only then be th PSU or power supply unit, take it to your local tv repair shop of mastercare somewhere like that, its going to be cheaper to get it repaired than replacing the whole tv
PSU'S generally 20 to 50 pounds depending on model
don't deo it yourself though unless you've got a capacitor discharger (or a nice 25KV will be on its way to your body)
hop this helps mate, let me know how you get on
Nov 10, 2007 | Televison & Video
Wont come on
Sep 06, 2007 | Beko 324250WN 28" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
