Question about Frigidaire FEF366 Electric Kitchen Range
Frigidaire Gallery Series ES340 ceramic-top range:
Frigidaire Gallery Series ES340 (GLEF3790SB) ceramic-top range: Self-cleaning doesn't work. Tried unplugging for a minute to reset microprocessor and holding the oven light button for 30 secs but no luck. No help from Frigidaire either except for names of repair places. Anyone have any ideas?
The manual is missing a step. After pressing Clean or Quick clean you need to press the ^ button once.
Posted on Sep 05, 2010
  • 4 Answers
The hinge appears to have a crimp by design. But after further evaluation, it becomes evident that the crimp appears on both hinges at the same point because of downward pressure when the door is in the open position. New hinges are suggested, however, a temp fix is to release the lock levers on the hinges as if removing the door. Then carefully apply upward pressure, evenly on the face of the door. Be very careful not to stress the glass. Good Luck!
Posted on Mar 06, 2010
  • Frigidaire Master
  • 19,396 Answers
Self cleaning mode towards the end of its cycle went into a failure code cleared it by flipping breaker. Now when I run bake/convection it runs broil at 600. Lower oven now run under temp.
Amazon.com: Frigidaire Gallery 27 In. Stainless Steel ...
www.amazon.com/Frigidaire-Gallery.../B002HMRIBI
Amazon.com, Inc.
Rating: 4 - ‎4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire FGET2745KF Gallery 27 Double Ele
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
Jan 03, 2016 | Frigidaire FGET2765KF
My frigidaire self cleaning oven says F90?
Lift top - there is a quater inch button on the black box behind the door lock - use screwdriver to press the button in - resets
Sep 17, 2012 | Frigidaire 27 in. Electric Gallery Pro...
Frigidaire gallery convection fan doesn't work
Found this site cuz I had the same problem-didn't find an answer but messing around I figured it out... I pushed the QuickBake button to preheat then to turn the fan on I pressed it again... ( actually a couple times messing with it...) Once it gave me a " double beep" and sometimes just a single beep but none the less, the fan turned ON!!! Good luck!
Nov 07, 2011 | Frigidaire Gallery 30" Self-Cleaning...
Frigidaire Model CGLEF379GSA self-cleaning stove with ES340 Control: Won't self-clean after following instructions in manual.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Jan 04, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
How to unlock the frigidaire oven range door and remove error F3?
How do you adjust the oven door on a Fridgedaire Gallery Series gas stove?
Jul 13, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Self cleaning oven won't lock
Generally
There is a motor that lets the latch slide out and catch the door either this latch motor isn't getting power from the board or the motor is bad. You will have to need a volt meter and a wire diagram, and take the covers off to see the motor and board.
Always remove power until you get the item open and can see whats going on before reapplying power.
If you don't feel confident I recommend calling in a repair man.
Mar 08, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
The digital display does not come on
you have a burnt board thats going to need replacing.that was the pop you heard and the puff of smoke.
Dec 28, 2008 | Kitchen Ranges
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire FEF366 Electric Kitchen Range Logo
2,366 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
