Question about Garden
Why my comet pressure pump Hw 3540 is lose pressure
2 Suggested Answers
lilmikew99
  • 122 Answers
SOURCE: Oil for Comet pump
aftermarket oil will be fine just use same grade of oil,all manufacturers want that extra kick,
Posted on May 12, 2009
Y a t'il un niveau d'huile dans la comet bxd 2525
L'utiliser cette pompe sans huile est une erreur fatale:
[PDF]COMET PLUNGER PUMP SERVICE MANUAL INDEX
www.cometpump.com/_images/support/Pump_Repair_Manual.pdfLUBRICATION: Make sure crankcase is filled with Comet Pump oil. Running this pump without oil will cause damage and void any warranties. Change the pump ..
Mar 14, 2014 | Comet BXD 2525 G Pressure Washer Pump
B&E pressure washer w/ comet 3540 pump
Things to check:
1) is water coming out of the bottom of the pump or is the oil in the crankcase high level and milky yellow. If so your seals are bad.
2) Your check valves might not be seating properly. A couple of fouled check vavles will cause either no pressure or pulsing pressure. A good inlet water strainer keeps foreign matter out of valves. But valves do wear out and get build up that keeps them from working right.
3) Your unloader valve might be worn or fouled. Bad unloader would usually show as low pressure ( but more than hose pressure) or low volume out the trigger nozzle.
Valves are your most likely problem.
Feb 17, 2014 | Comet Pressure Washer Hw3540s Triplex Pump...
Oil seeping from Comet BXD 2525 pump
out the drain plug ? Sight glass window ? Under the pump where the crankcase meets the pump head?
tighten plug, replace oring on sight glass or replace low pressure seals if near the pump
Dec 09, 2013 | Comet BXD 2525 G Pressure Washer Pump
Comet water oil
You have to take off the pump head. Here is the link to the service for comet pumps.
https://www.pwmall.com/PDF/CometServiceManual.pdf
Nov 03, 2013 | Comet GXD2527G Pressure Washer Pump
On our electric pressure washer. Nolonger works. Disconnected the pump from motor. Motor spins freely. My guess is pump is bad?mike
Good guess. You can find parts at: www.pressure-washer-parts.com
They handle comet pumps. See if you can find the number on the pump. Not a bad brand of pump,but they do wear out. Never run pump dry, never let idle more than a couple of minutes, the water recirculates in pump and gets hot. Install a temp relief vavle when you rebuild.
Jun 27, 2010 | Comet GXD2527G Pressure Washer Pump
I have a Comet 4040 and oil and water mix is bubbling out of the red cap on top of my pressure washer. Can anyone tell me what repair kit I might need to fix this problem?
Hi this could be the oil and pump seals worn. Also make sure that you don,t have the transit plug in or the pump cannot breath. It should have a air vented dipstick.
May 21, 2010 | Comet GXD2527G Pressure Washer Pump
Comet pump will not release from gas engine. Can you help? Thanks
Sometimes you can put the bolts on the pump loose and run the machine. The vibration from the motor will work the pump loose. If you do that, remove the brass head or the pump will overheat.
Dec 01, 2009 | Comet BXD2527 Pressure Washer Pump
What kind of oil do I put in my Comet AXD2524G-T pump?
If the Comet Pressure Pump Oil is some kind of a
Synthetic Oil that supposed to be extra effecient than
an ordinary oil, then that will cost extra. If that is ordinary multi grade engine oil (SAE 20 - 40), then, you
can buy over the counter. Most synthetic oil have additive that give extra longer life to all moving parts.
Nov 27, 2009 | Plumbing
Comet 2.5 Gpm pressure washer pump wont **** soap anyone know what you have to do to make it start sucking soap
I have found many comet pumps to be plumbed wrong from the factory. Look on the side of the soap injector and look for the flow arrow, make sure its in the right direction. If it has worked in the past,then take it apart and replace the spring, check ball and seat.
Nov 03, 2009 | Comet GXD2527G Pressure Washer Pump
Oil for Comet pump
May 12, 2009 | Comet GXD2527G Pressure Washer Pump
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
