Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 2550 chainsaw does not lube the chain
How can I troubleshout chain lubricaton  problem ? I cleaned it around the spracket and it has plenty of oil but the chain is dry.
  • 398 Answers
Sometimes the oi lpumps fail or get clogged youll have to take it apart and replace/clean the pump. let me know if you want more instructions on this
Posted on Apr 24, 2009
Chainsaw won't idle- runs fast only
Gently Tighten the carb adjustment screw fully tight then adjust it out 360 (full turn) then again a further 180 ( half a turn) and your idle speed should be set correctly. Let me know how you get on
Oct 02, 2014 | Oregon Poulan/Poulan Pro 10" Chain Saw...
Poulan 2550 18
There is no problem as long as the bar is the right bar and the new chain you use is the right pitch for the sprocket that is on your saw.
Nov 14, 2013 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain Lube Leak
It is the nature of the beast. Many chainsaws suffer from this malady. I own a bunch.
Lou
Try loosening the oil cap prior to bed.
Aug 04, 2009 | Poulan Pro Chain Saw 46cc 20"
I have a poulan 14" chainsaw that doesn't seem to supply enough oil to lube chain.
make sure bar is clean and all debris from area under chain cover
Apr 28, 2009 | Garden
Poulan 18" Chainsaw - Motor runs fine but blade stopped spinning
Chain may be locked in the bar. Caused by low oil flow to chain. You will probably have to remove the bar and blade. Then try to rotate the sprocket, if it will not rotate you may have to replace or repair the clutch. with the blade off try starting the saw and see if it is oiling. There is a small hole in housing that oil should be visible coming out at a fairly good rate. If not you will either have to open orifice in the housing or repairing the oil pump.
Apr 11, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain Lube Pouring Out of Chainsaw
We can see no more detail than can you.
This is a collection of chainsaw enthusiasts that may provide a better answer. Be prepared for a little grief because you a Poulan.
ArboristSite.com Chainsaw thread
http://www.arboristsite.com/forumdisplay.php?f=9
GL
Lou
Feb 22, 2009 | Poulan Garden
Poulan Pro Chainsaw PPB1838 Bar Lube Leaking Out
If this is a Poulan as listed I would go to psep.biz and look at a schematic for the tool. You would need the model number and type number but their breakdowns are good.
Feb 14, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan pro series chain saw 20" bearings seizing up on bar
check sprocket isn't worn it may be pulling on chain than over heating bearing. check pitch of chain ,bar , sprocket are the same.
Dec 29, 2008 | Poulan Garden
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
339 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
