Elddis caravan porch light bulb blown cant remove cover
Porch light doesnt work i think the bulb has blown i cant seem to remove the cover to replace it can you pleae help thnax mark
    Brigadier General:
  • 10,406 Answers
Take a pair of safety glasses, work-gloves, and a hammer, and swing the hammer to break the cover. Remove the whole unit, and replace it with an energy-efficient LED light & socket.
Posted on Dec 02, 2009
How do I remove the porch light cover, to change the bulb?
Steve, A picture would help but maybe this will help. Most porch light lens have three tabs if oval or maybe four if rectangular. Push the edge at the bottom up and look closely. If it is old it may need gentle help from a wide blade like your wife's OLD kitchen knife. Careful, it is probably brittle. It may have been mounted upside down so try the top, too.
Jan 20, 2016 | Holiday Rambler 2011 Endeavor 43DFT
The tail lights on my 2006 dodge grand caravan don't work. Any ideas as what could be wrong?
Check that the fuse is not blown and that there is no wiring fault. Otherwise check that the lights are not blown as well, and look at the following YT video to illustrate the removal of the light:
How To Install Replace Taillight Dodge Caravan Chrysler Town and Country...
Another useful link is:
Dodge Caravan Tail Light Bulbs Replacement Guide Brake Parking Signal...
Feb 12, 2015 | 2006 Dodge Grand Caravan
How to change a light bulb of a tail light
Remove the tail light cover from inside the van, pop the cover first, then remove the socket by turning it left about hlaf a turn, it will pop out, remove the burned bulb, replace with new one of same type, assemble back reverse of removal.
Good luck.
Aug 20, 2011 | 2001 Dodge Grand Caravan
Can't find light globe in MC924JLA LG Microwave
I think you're referring to the bulb which is not working. You have to remove the cover from the microwave to gain access to the bulb. Replacements can usually be found at appliance repair shops or stores and electrical or lighting supply stores.
Jun 21, 2010 | LG Microwave Ovens
89 Toyota Pickup right turn signal doesnt work just buzzes
check all bulbs,inspect sockets for corrosion,rust ,or sighns of overload.follow wires and check connectors if all good ,replace the flasher ,,if that doesnt fix it ,the blinker switch in the steering coulmn would be next
Sep 22, 2009 | 1990 Toyota Pickup
Amana Microwave bulb I cant seems to access, model # AMV5164ACS??
The owner's manual shows you to to access and change them.
Your exact model is not there, but the similar models (like the BCS suffix) should work just fine.
COOKTOP/NIGHT LIGHT REPLACEMENT
CAUTION
To avoid personal injury or property damage, wear gloves when replacing light bulb.
1. Unplug the oven or turn off power at the main power supply.
2. Remove the bulb cover mounting screws.
3. Replace bulb with 40 watt appliance bulb.
4. Replace bulb cover, and mounting screws.
5. Turn the power back on at the main power supply.
OVEN LIGHT REPLACEMENT
1. Unplug oven or turn off power at the main power supply.
2. Open the door.
3. Remove the vent cover mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
5. Remove the charcoal filter, if present.
6. Press and hold the center snap while lifting the tab on the left corner. Remove the cover. Remove
the bulb by turning gently.
7. Replace bulb with a 40 watt appliance bulb.
8. Replace the bulb holder.
9. Replace the grille and 3 screws. Turn the power back on at the main
power supply.
Jun 26, 2009 | GE JVM1650 1000 Watts Microwave Oven
Bad groind in subaru, HELP!
earth is making contact with the live at the bulb holder.remove and check.Make sure you have the right bulb in it.then replace the blown fuse.
May 30, 2009 | 2006 Subaru Outback
Replace dome light bulb 2005 dodge caravan
Have you checked your fuses? If it is not a fuse then take a flathead and gently pry the cover off, remove light and take with you to parts store for replacement comparison, replace light same way other came out and replace cover. Check your owners manual for specific fuse locations.
May 17, 2009 | 2005 Dodge Caravan
Computers & Internet Logo
337 people viewed this question
David Payne
David Payne
