Question about Magnum Remusshield Finger Touch Immobilizer Honda Aquatrax F-15
Ldv maxus dose not start immobiliser fault - Magnum Remusshield Finger Touch Immobilizer Honda Aquatrax F-15
LDV MAXUS 2.5 DIESEL DIAGNOSTIC FAULT CODE P1145
The owner's manual should have code information if it is equipped for self diagnosis, Like the Chrysler (Limp mode self diagnostic system)
Chrysler and some Mitsubishi models prior to the split, Those codes can be found @ Allpar.com or the manufacturer's website for most others, If a friend or someone you know lets you borrow a code reader, plug in after you set the parameters and the code you read might be different for that model but should lead to a solution.
Dec 02, 2013 | Motorcycles
How to fix 5th gear on my ldv maxus
Its likely you have a problem with the clutchnot completly disengageing or problems with disk or pressure plate
Jun 13, 2013 | 1997 Chevrolet Cargo Van
Help!!! how to reset a LDV Maxus key fob?
Hi
I know from experience that you cannot really re synch these fobs on the LDV Maxus vans.
What actually is the fault is an onboard component on the pcb has failed and we normally just replace that with a new one..the fob will be tested for operation and sent back. OR its the Relay in the ESA unit - under the left hand front glovebox on the bulkhead - black with cables going into it. We have those relays (soldered to the pcb) we can supply those or do the work for you. The fob connects to that ESA and the unit then fires the relays to open/close the doors. Sometimes that unit is installed upside down which causes water (condensation) to enter the box and have fun with your electrics.
The fob is SYNCHED to this unit via coding we can use your old fob to clone to a new fob and that will work with the ESA and the vehicle.
We have the parts on this link Items for sale from remobilise ltd
Here is a link to how to program the fob to the vehicle via the programmer - NOTE how you MUST have a working fob to program another (text at the start of the video... LDV Maxus flv
We can fix most problems on the LDV Maxus that occur with faults to do with the Central locking/fobs/ESA/ETACS - three relays are in the ESA and they control ONLY the central locking - two more relays are in the ETACS unit (behind the ashtray) and they control the fogs and intermittant wipers.
Any help or info needed please contact info@remobilise.co.uk
or tel 01792 896404.
We are based in Swansea UK.
Aug 30, 2012 | Cars & Trucks
LDV Maxus
Please re post this in the car and truck area as this is listed in the DVD area.
Jun 16, 2012 | Televison & Video
Ldv maxus fault code p0402
Airbag warning light goes out on starting but comes back on after about 5 seconds
Jun 14, 2012 | Cars & Trucks
2007 ldv maxus 2.5 van will only start with easy stast and it comes up with 1 fault crank position sensor
next would be to check the fuel pressure at the fuel rail (under hood @ fuel inj sight) It sounds more like a fuel delivery problem then an electial problem
Jun 03, 2012 | Cars & Trucks
I have a LDV Maxus Van, The problem is it only starts with a tow and then runs fine and the minute i turn it of it needs a tow again
Hi have you had any joy finding fault I have the same problem with my Maxus. I've replaced endless stuff even main pump ,narrowed it down to crank position sensor.but sensor is fine there should be a 5v feed but there isn't one ,checked wire back to ecu and its ok. But carnt see it being fault on ecu van drives and performs great once running. Seems to be quite a common thing on these but no one seems to have an answer, if you have any joy with yours or need any questions over it you can contact me on d-scott13@live.com for number , cheers dave
Dec 09, 2011 | Chevrolet Venture Cars & Trucks
How do you program remote central locking on ldv maxus as the remote is sending out a signal as we ahve had this checked but it doesn't lock or unlock the van
it sounds like its either the fob or the esa unit if its the unit it needs to be programmed by an LDV dealer using the diagnostic equipment
Feb 16, 2010 | Vehicle Parts & Accessories
How is the central locking meant to operate on an LDV Maxus Van
the central locking can be programmed to either unlock and lock all of th edoors together or by opening the drivers door with the first press of the fob and then unlocking the doors with the 2nd press. the load doors will then lock after a pre determined time for security
Oct 21, 2009 | Vehicle Parts & Accessories
Magnum Remusshield Finger Touch Immobilizer Honda Aquatrax F-15 Logo
16 people viewed this question
Top Magnum Tuning Vehicle Parts & Accessories Experts
mekanik84
 Robert
Robert
Level 1 Expert
xkikbxr
Are you a Magnum Tuning Vehicle Part and Accessory Expert? Answer questions, earn points and help others
