Question about Samsung SGH-D600 Cellular Phone
Not vibrating i dropped my phone on a carpeted floor and since then it does not vibrate
    Sergeant:
  • 452 Answers
1. Because ur handset dropped so definitely its ur vibrater's connection which has broken, u just visit samsung service centre and they will simply repaire or change the vibrater of ur h/s.
Posted on Oct 11, 2007
SOURCE:
How to fix a bouncing floor
Is your floor the problem, or a vibrating wash machine? You can buy feet for an appliance or put carpet underneath it. anne melhuish
Jan 25, 2012 | Washing Machines
Does the vacuum lose suction when in the floor mode if the belt is broken?
To put it simply, no. By floor mode I'm assuming you're stopping the brush roll from turning so that you can clean hard surface floors instead of carpet. When the brush roll doesn't turn you do lose agitation which vibrates the carpet so that the dirt is more easily picked up by the vacuum. But you don't lose suction because the brush is not turning.
May 18, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Vibrating machine
have you check your floor..if floor is weak the hold area around unit will vibrate,,,easy test,,,stand in front of unit and bounce your body up and down things moving,,,weak floor,,cheapest fix..get a piece of pluss carpet and make 1 piece over all for legs,,when unit settles in thick carpet that will stop bouncing and noise
Dec 09, 2008 | Maytag MAH8700A Front Load Washer
Kenmore 22932 Top load washer has excessive vibration at end of spin cycle
IF THE FLOOR IS NOT ABSOLUTELY STABLE, IT WILL MAGNIFY A SMALL VIBRATION INTO A LARGE ONE. PUT SOMETHING ON THE DRYER IF IT SETS NEXT TO THE WASHER, AND TURN ON THE WASHER INTO SPIN. IF THE ITEM ON THE DRYER SHAKES, THE FLOOR IS MOVING.
IF THE WASHER IS ON CARPET, REMOVE THE CARPET OR CUT HOLES IN IT WHERE THE FEET ARE SO IT IS NOT SETTING ON THE CARPET. THE CARPET AND PAD WILL BE TOO SOFT FOR THE WASHER TO SET STABLE.
ALSO, PICK UP ON THE REAR OF THE WASHER TO RESET THE AUTO LEVELING REAR LEGS. YOU SHOULD HEAR THEM MOVE AND RESET WHEN YOU SET THE WASHER BACK DOWN.
Apr 03, 2008 | Kenmore 22422 Top Load Washer
Motorola krzr k1m stuck on vibrate
So my girlfriends phone wouldn't stop vibrating either...so I just threw it on the carpeted floor (throw it somewhat hard, obviously not hard enough to break it).....then the vibrating stopped.....worth a shot I guess if you don't want to go through the hassle of sending it in.
Feb 08, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
SPH-M300 continuous vibrate
I can solve this problem drop the phone on the floor, the problem is that the programming of the phone has messed up and is keeping the vibrating going so either buy new phone or keep dropping the phone till it stops vibrating
Jan 26, 2008 | Samsung SPH-M500 Cellular Phone
LG VX6100 - Won't stop vibrating
my phone barely got wet at all but wont stop viberating either.everthing else works fine. i set it on a table to go on the computer and the viberating just stopped and i dont know why but right after that it just started viberating again. i got some tips from some other people that didnt work 4 me but it might work 4 u. u could try doing a master reset which just taking out the battery when the phone is on and it resets or u can try blowing on the battery in case it somehow got some dust on it.
Oct 21, 2007 | Cell Phones
Samsung SGH-D600 Cellular Phone Logo
164 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
