Question about Taylor Pittsburgh Manufacturin Taylor Pittsburgh 4 Sub-Compact Gear Driven Rotary Tiller 923-GDT-48
How do I find the right length to cut pto shaft
PTO turns with mwoer shaft disengaged, blades turn when shaft is rotated by hand. Put shaft into PTO housing and the mower wont turn.
bad pto, 400 dollar to fix but a cheap option is to replace the pto switch in the dash first, is the pto switch clicking with the key in the ON position? if it is then it is the pto clutch bad
Jul 29, 2015 | Garden
My pto engages on the highest level for my deck on my mtd lawn tractor. Highest my deck will go is 5. But when I put it to 4 ir even 3 the pto cuts out. But as soon as you return it to 5 it starts
Owner's manual? no manual, try for both owner and Repair manual on manualslib.com
Wild guess, the angle of the PTO drive shaft related to the height of the deck is causing a problem. Perhaps it's binding and won't turn, or pops out because of the binding and load. Perhaps the drive shaft is not "locked" on for some reason, with pins or
another device. Perhaps the sliding portion needs lubrication.
Apr 06, 2015 | Mtd Garden
Briggs&straton all the oil leaked out from under the engine. the engine oil
hi there donald77
provided you have not got any cracks in the sump plate and the sump plate bolts are tight
sounds like you have a worn out pto seal ( please check pto for bend or wobble ) as this could have caused this from hitting something solid
it it is bent have it straightened before proceeding
remove the blade carrier and hub and key - clean up the pto with emery tape , drain oil , use a straight shaft flat blade screwdriver and lever the seal out of position
obtain a new seal place some thin plastic sheet ( from say a thin walled plastic container )
cut into a size that you can wrap around pto , then slide the seal over it up to the opening ,
the drive the seal into the housing squarely until the seal is flush with the housing ( on a non stepped pto ) 7/8 shaft
but on a stepped pto 25 mm drive it in further until its about 3 mm below the housing
reassemble and refill with oil
cheers hope it helps
pauly46
May 30, 2011 | Garden
I have a pto shaft that has boke in my case david brown 885 and i have it torn down to the pto shaft right now i just need to know how to get the shaft out
Take the gears out.Bell housing side of pto shaft, insert punch in hole and use allen wrench to remove plug on shaft end. use punch in allen screw hole to drive shaft out of housing (don't mess up the threads!!)
Aug 16, 2010 | Milwaukee Tool Case Heat Gun
Krone AM322 disc mower pto runs disc will not turn
sounds like a broken shaft in the gearbox!
Please rate my help++++Thanks for using FIXYA
May 12, 2010 | Krone Patch panel
I just got a 5' KK rotary tiller and the pto shaft fits onto the tractor just fine with the button lock. The other end doesn't want to slide all the way onto the tiller gearbox drive shaft. It only goes...
http://www.youtube.cohttp://www.everythingattachments.com/Tractor
http://www.everythingattachments.com/Tractor-3-Point-Hitch-Tillers-Rotary-Tillers-s/76.htm
go to the second site first, it will explain your "problem.". Your problem is you need to adjust the length of the pto shaft to your particular application. not all pto shafts fit all attachments "out of the chute"
once the shaft is adjusted OR prio to modifying it, view the first video. both or very well presented. i've been there!
Happy tilling!!
steve wood
Rancho de Suenos
Albuquerque, NM
Mar 10, 2010 | King Kutter II Gear Driven Rotary Tiller...
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
I have a JD 1070 4 wh dr, when running a brush hog on the back pto, what would make the pto shaft slow down under a load when cutting light brush, funny smell. Checked all oil levels.
Reading on line, I see your tractor has a PTO clutch. It must be slipping. It either needs adjusted or replaced. A slipping clutch disc will make a bad smell.
Jul 28, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Taylor Pittsburgh Manufacturin Taylor Pittsburgh 4 Sub-Compact Gear Driven Rotary Tiller 923-GDT-48 Logo
42 people viewed this question
Top Taylor Pittsburgh Manufacturin Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Taylor Pittsburgh Manufacturin Garden Expert? Answer questions, earn points and help others
