Question about Epson Stylus CX5400 All-In-One InkJet Printer
Printer problem Hi, I haven't used my printer in about 3 months, and i just replaced all of the ink cartridges. But when i go to print, only blank pages come out. There are no warning messages that say there is any problem with the connections or anything, it just prints normally, except the pages are blank. Please help!!!
  • rose15 Jan 19, 2008
    Where can i get this type of syringe? and where is the 'spigot'
    Genius:
  • 2,985 Answers
The Jets have dried out Which is seroius on an Epson because they are part of the machine. There is a tool you can make thats will help to clear the problem- but it will be long job. Contact also www.fixyourownprinter.com
Posted on Sep 24, 2007
  • Anonymous Jan 20, 2008
    The syringe is available from ink refill suppliers mail order usually- but any small syringe will do
    The tube is Fish tank air line.
    The spigot is in the base of the ink chamber- it is the 'spike' that pierces the cartridge
    Take a look at this also simply click on the link
    [URLhttp://www.imagethrust.com][IMGhttp://i107.imagethrust.com/i/691927/ink...[/IMG][/URL]
SOURCE:
Blank pages printing
Sounds like the printhead is pretty severely dried. As standard cleaning cycles haven't helped I would recommend picking up some LC900 cleaning cartridges from eBay etc. These are cartridges filled/partially filled with cartridge flush and break down ink inside the printer.
Most of them contain a mix of ink and flush and you can carry on printing as usual. Given the severity of the dried/blocked printhead you have I would recommend just running cleaning cycles, but leave 10 minutes or so between cleans to avoid overheating the printhead.
Oct 16, 2012 | Brother MFC-5440CN All-In-One InkJet...
Hi! The printer does not print colors or black. I have full new inks, an i have cleaned it many times, but it does not give any viewable text.
Hi, this is a very common problem when you leave the printer without use for many months . To fix that, you have to take your printer to a custom Technical Service and ask for a simple head cleaning. It'll be a cheap work.
_OR_
If you want to do it for yourself, get some Isoprophilic Alcohol (also, you can get Deionized Water) and follow the next steps:
1- With a syringe (one for color), remove all the ink of your cartridges.
2- Put that ink on different recipients and save it for later. 3- With a new syringe, put the isoprophilic alcohol in the cartridges. 4- Leave the cartridges all night. 5- Put the cartridges back on the printer and turn it on. 6- "Print" as many pages you can. This'll make the isoprophilic alcohol pass through the printer's head and make it "believe" is printing normally. 7- When you're done, remove the isoprophilic alcohol of the cartridges and put the ink back on the cartridges. 8- Put the cartridges back on the printer and start printing. This prints will be desaturated or blank. 9- Keep doing it until the printer is working correctly.
This is what they're gonna do at the technical service. You choose what to do.
Hope to help you.
Steelmith
Jun 20, 2011 | Office Equipment & Supplies
Hp photosmart 8050 won`t print black even though it says it full
Hi there! If you haven`t used the printer in 2-3 months the black ink cartridge has gona dry.Wich means the printer is seeing full ink but the ink isn`t actually coming out from the ink head.Take a peace of clean cloth or cotton and clear the bottom part of the ink head(be verry carfully while cleaning it cuz you may dmg the head.If that doesn`t help just go and buy a new ink cartridge and it will solve your problem.
Nov 10, 2010 | HP Photosmart 8050 InkJet Printer
Can the ink dry up. installed printer ink a couple of months ago but will not print now. printer prints blank pages.
hi!
yes ink can dry up.. big chance your ink have dried up, since you've installed them couple of months ago.. there's a possibility that the ink may have not dried up but the print head may clogged.. you can try running some maintenance like clean cartridge or print head test using Dell All inOne Solution center..
Hope this helps..
Sep 11, 2010 | Dell V313w AllInOne InkJet Printer
Hi. Printer isn't working, paper comes out blank.
Most likely the printhead is clogged. Another possibility is that the cleaning station does not work. 3 ways the printhead can clog,
1. Using Generic Ink
2. Not using the printer for a long time
3. Print a large print job after the ink indicator says the inks are running low.
You are better off replacing the unit than trying to get the printhead unclogged. Cost is usually around $40 and is only a 65% chance it willwork.
thanks
Dec 17, 2009 | Epson CX4600 Stylus Color All-In-One...
Printing papers centre is blank
Hi....You haven't written your printer or cartridge model.
Then also if it is a laser printer.take out cartridge from the printer.....shake it up & down 3-4 times.again insert it in the printer and now check the print..if it is ok....it means that toner level in your cartridge has reached low level and cartridge needs to be refilled.
Aug 28, 2009 | HP LaserJet Q2612A Printer
Black Ink won't print
epson printers are very picky about the ink it could be possible that the off brand ink has ruined the print head
Feb 10, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Hi, I haven't used my Canon S330 printer for some months, and when I plugged it in just now, it wouldn't print. I replaced both cartridges, and still no printing. The cartridge moves fairly quickly back...
in the print head there are hundreds of minute holes from where the ink of the cartridge comes out when you remove the head check whether the ink is coming from the holes in the head .if the ink is not coming the head may be dry and if the very less ink is coming then some of the holes are blocked. the ink has to come out from that holes for printing.
thanks.
Sep 18, 2008 | Office Equipment & Supplies
Will not print---prints blank pages
This printer is 13 years old. I am a fan of keeping things around,  and those cartridges for $3 arent bad, but its not the best on the environment, and considering printers of this decade print faster, have better resolution and are capable of archival prints.
It's really worth it.
Hope this helps.
Oct 10, 2007 | Apple Color StyleWriter 2400 InkJet...
Epson Stylus CX5400 All-In-One InkJet Printer Logo
112 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
