Question about Watches
How do I strap theorema rio skeleton watch to wrist can't get strap past pin in butterfly clip
5 Suggested Answers
Kimi
  • 277 Answers
SOURCE: Calvin Klein K7111 brown watch strap
try here: http://www.a1watchbands.com/ for example: http://www.a1watchbands.com/product_details.php?search=&id=712 or try on ebay, for example: http://search.stores.ebay.ie/calvin-klein-strap_Watch-Parts-Accessories_W0QQcatrefZC6QQsacatZ10324
Posted on Aug 17, 2006
SOURCE: Adjusting the strap
Most clasps have a series of small holes drilled in them, and the end of the strap is held in by a small, spring-loaded bar whose ends are seated in one set of holes. Take the end of a small paperclip, or a large needle, and use it to depress the spring-loaded pin. You can then carefully slide it to another set of holes to make the band smaller. Don't let the ends of the pin slide all the way out of the clasp, or it might shoot off into space.
Posted on Jan 22, 2008
escapement
  • 2334 Answers
SOURCE: Strap for Fossil Philippe Starck PH1035 Wrist Watch
Type in your browser FOSSIL WATCHES.
You will find numerous sites. Go thru them till you find what you're looking for.
Posted on Dec 19, 2008
  • 2501 Answers
SOURCE: watch dial says 'WITTNAUER
Go to "www.allamericanwatches.com/" which is the Boluva site but they deal in this make. Put "straps" into their search box and a list of straps appears.
Alternatively, go to "wittnauer.watches-collection.com/". This company sells replicas, so presumably will be able to offer you a replacement strap.
Posted on Jan 02, 2010
How to remove stainless steel wrist band on a marc
You should find a couple of pins buried away at the watch side of the strap. These are spring loaded and hold the strap in place using tension.
Simply put the watch face down on something soft, the clips should be visible at the corners of the strap and take some needle nose pliers or small flat screwdriver and push inward from one of the outer edges. This will squash the spring and enable you to remove the strap.
Oct 15, 2014 | Watches
How do yu remove raymond weil watch strap pins?
It depends on the strap as there are several different types.
But I suspect the one you have has pins that go through the whole metal wrist band.
You need a special tool that pushes out the pin, these normally only come out in one direction.
There should be very small direction arrows on the back of the strap if that is the case.
When putting them back in again they must go in the correct direction.
Look on ebay for wrist watch strap removal tool, looks like a mini vice with a small handle and pin pusher the other end.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Watches
Does my 2010 invicta corduba have pins or screws in the braclet? how do I remove them? They look like screws but juts spin around both way when i turn them.
Sometimes the split ends of pins look like screws. If the slot is extremely thin its a pin A screw slot will be a bit wider. I pin removal toll inserted into the smaller end should do the trick.
Apr 30, 2010 | Invicta Corduba Skeleton Techno Strap...
I own a titanium luminox and I have replaced the pins that attach the band to the watch it self twice. Where can I find Heavy Duty pins or something? Can I buy a repair kit to install the pins? Thanks in...
I used to have similar problems when I used to used leather (rigid) straps. I found that flexing the wrist used to pull the straps off the watch.
I got over the problem by using expanding bracelet. I have never had the problem since (30 years!).
Jan 18, 2010 | Luminox Dive 7202 Wrist Watch
How to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
Feb 10, 2009 | Nixon Scout NIX0013 Wrist Watch
The user guide is wrong
I have a Theorema Parago Automatic through not wearing it regularly it sometimes stops. Winding it wouldn't solve the problem and I couldn't find a solution either on the Theorema site or online so through a series of self help efforts the following is the solution for this watch 1 Set the watch to the correct time date day etc. 2 Wind the watch using the side winder for about 40 revolutions in clockwise rotation 3 Hold the watch in your right and strike it firmly into the stiff palm of your left hand. This gives the winding mechanism a shark shock and kicks it back into life.The watch then works away without a problem.
Nov 17, 2008 | Ebel Tarawa Automatic 9127J40/5435136...
How to adjust the watch strap
I just bought the o-ring watch by Starck, and it looks to have the same style of strap. If you look on the side of the clasp, you will see a pin on both ends. You have to remove these retention pins first (which may require tools that are unavailable to you). First, stabilize the watch on its side on a soft mat - I used the back of a mouse pad. Then, use a thin, stiff piece of metal tool to push the pins out slightly. I used a crafting tool. Once the pin sticks out enough, you can use a fine set of pliers to pull them the rest of the way out. (If this does not make much sense at this point, you may be best off going to watch shop.) Once you remove the pins, the clasp can be removed from the strap simply by lifting the clamp. You then trim the strap with a pair of sharp scissors to the appropriate length - make sure you see exactly what the end looks like, because the shortened strap will need to have the same apperance. After trimming, reclamp the clasp onto the strap, and reinsert the pin. You may need a small hammer to get the pins seated completely. Then, you're done. So obviously intuitive, why would anyone need directions, right? Honestly, Fossil did not make this one easy at all. Kind of irritating.
May 15, 2008 | Fossil PH1057 Wrist Watch
Adjusting the strap
Jan 22, 2008 | Versace 27473-008-00 Wrist Watch
Band removal
There are two little pins on the strap. They need to be pushed to the side to release the strap
Dec 24, 2007 | Nike Triax 10 WR0006-001 Wrist Watch
Watch stops
sounds like the oil is contaminated and causing undo friction or the main spring is ether broken or slipping. Time to service your watch. call me 707-338-3207 www.finewatchmaking.com
Mar 01, 2007 | Ebel Tarawa Automatic 9127J40/5435136...
Watches Logo
546 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
