Question about Refrigerators
GE GSH22JFRE WW not dispensing ice
A few weeks back i noticed my water and ice dispenser on my refrigerator was not working. Now the water is working and it is making ice, but not dispensing any. When i push down on the lever the light dims and it seems to shut off almost. When i let up on the lever the light seems to come on stronger and it sounds like something is starting like a fan. I have GE coming this thursday but would like to try to fix it myself before. BTW the ice door opens when you press on lever. It seems like the arm in the back will not turn. Thanks, Debbie
  • 2 more comments
  • gblairgolf Feb 11, 2008
    We are having the exact same problem. I read the two responses, and we already planned to empty the bin, and make sure the auger is free.
    In reading the response from "SolutionGuy", I am assuming his referral to the facia is the plastic "surround" that fits on the front of the door, around the control panel?
    Secondly, two models of the control boards were mentioned. Is one better than the other? Are they interchangable?
    Lastly, is the "fix" really as easy as it sounds, as you described it, even for a modestly mechanically challenged person?
    Thanks,
    GBlair
    Also, the ice bin gets really full. Is there an "on-off" switch to stop ice for awhile. Previous i/m had a bale-arm you could push up to stop ice from being made. I think because the bin get's full is the reason why I do not get whole cubes; just crused, regardles of which setting I use. Does this make sense?
    Thanks
    GBlair
  • mleach917 Nov 11, 2008
    I have the same problem with the ice not dispensing and lights going dim. I had ordered the new panel and replaced it and it has not fixed the problem.
  • Anonymous Mar 23, 2014
    no water comes out when you push the lever
    President:
  • 331 Answers
Deb, sounds like your dispenser control board has given up the ghost. The boards come in 2 models, 4 button and 5 button. The 4 button part # is WR55X10443 (~$87.00)... the 5 button part # is WR55X10437 (~$97.00). Not too difficult to replace. UNPLUG YOUR FRIDGE!!! Remove the drip tray from the dispenser, and any screws hiding in there. Then, using a flat screwdriver and starting at the bottom of the fascia, pry the fascia away from the door and remove. Then remove the screws holding the control in place and disconnect any wiring. (Don't forget to pay close attention to WHERE the wires connect and HOW the wires are routed!) Then install the new board and rebuild. Approx. repair time for your first one is ~1 hour. Good luck!
Posted on Sep 25, 2007
My fridge is only a couple of years old, not making ice (or even hearing any sound when lever is pushed in); now the freezer isn't freezing things, just keeping them cold and fridge doesn't seem to be as cold as it should....help...
Posted on Apr 01, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Hey Deb, the first thing I would check is the Ice dispensor bin is blocked. If you have water and ice but the ice is not dispensing, that is the first thing I have my clients check. all it will cost you is the ice in the bin. once you empty the bin just use hot water to melt any ice that is jammed drier with a paper towel and re instal. if it is more than that the GE tech should catch it.
I have a GE GSH22JFTA WW that will not dispense water. Does dispense ice, crushed and cube. Panel is not locked. What part do I need? Thanks!
in the back of the fridge there is a module with the solonoid on it to open and close for the water, and it usually get damaged because of hard water, it is about 15.00
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Aug 29, 2014 | Refrigerators
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator/model GSS201EPH WW. Water dispenser works fine, ice dispenser does not work
there is a pump which pushes water up to ice maker, it usually quits, causes the prob. 90% time
Jul 17, 2011 | GE Refrigerators
Water is not dispensed, but ice maker works. This keeps happeneng . what can i do myself? model number GSH22JFRE SERIAL LH206147
It appears that GE has a problem with the water line to the water dispenser freezing up. I solved the problem by turning on the light on the dispenser. (Note, it is not an LED bulb). After about a day and a half the water began to flow again. Have not had a problem since then
Feb 16, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Refrigerator GSS22JFMD WW with a ice
The water supply in the recessed part of your door is frozen. very common with this model. You will need to turn unit off and with freezer door open use hairdryer on the area where water dispenses and on the recessed area as well. This is time consuming but only other remedy is to leave off and door open for 24 hours. hope this helps.
Feb 12, 2010 | GE Refrigerators
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
Ice & Water Dispenser Suddenly Dysfunctional; LED lights, too!
Cory, you sound like you have a bad water valve as well as a bad control board for your dispensor. If you've had any storms in your area in the past 4 - 6 weeks, it's very possible that the storm took both parts out.
We have parts for GE as well as mots other major brands, so please give us a call with your complete model number and we will get your parts out to you right away!
We hope this solves your problem and we look forward to being able to assist you with future issues.
Have a great evening.
Nov 05, 2009 | GE GSS22JF Side by Side Refrigerator
My GE Refrigerator Clicks for hours but will not start.
Clicking you describe sounds like a bad motherboard. Water dispenser issues have been result of frozen water in the tubing in the bottom of the FF area, which you should not have at the moment, so if it is not dispensing water now I'd check the water valve coil. (there are two coils on the inlet valve, one for the icemaker and one for the water dispenser.)
Sep 26, 2008 | GE GSL25JFR Brushed Steel Side by Side...
Refrigerator will not dispense ice or water.
I have one the same model It done that about a month after I got it.
1995 Year I took of the left top corner the wires that make it work are in it. I wiggeled the wires around untill it started working and folded a card broad and put in it to hold the wires the way I wanted then put the cover back still works to this day.
Worked for me, Thank You,
Sep 02, 2008 | GE Refrigerators
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
879 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
