Question about Garden
After mower sits for a few days will not start with out turning motor over for a long time. After first start then it works ok, lt acts as though all the fuel has leaked fron line 155 john deere
    Scholar:
  • 128 Answers
Replace your needle in carburettor .
Posted on Apr 21, 2014
2 Suggested Answers
  • 221 Answers
SOURCE: I need to find a free diagram on how to route a
Try this link. I think it will help you out.
http://manuals.deere.com/cceomview/OMM142698_I0/Output/OMM142698_I011.html#40242
Posted on Jun 29, 2010
Cub cadet zero battery is dead after sitting a few days.
This is an electrical issue, you have a short in the harness, can very well be the keyswitch...even though you turned it to the off position, it's giving the unit the impression that it's still in the on position.
BriMaxSmallEngineRepairCo
Gibbstown,NJ
Jun 02, 2014 | Garden
Why my mower sputters while idiling and at times
If the gas is more than 30 days old, and it has been sitting in hot weather (90+), then it starts to go bad, rather quickly.
(And if no fuel stabile was added to the fuel before hand)
Or, if the gas can spout was not sealed properly in storage, it could have been water contaminated, from sprinklers or rain.
It may not necessarily be the motor itself.
The cheapest fix, is to drain all of the water out of the mower's gas tank. (you will still have some bad gas in the lines)
Put some fresh gas, with fuel stabile, in the tank and see if it will start. If it does, it may take a few minutes of operation to flush the bad gas out of the line, and motor.
That was the problem with my mower. It turned out to be a gas issue, and my mower was fine. Good luck.
Oct 16, 2013 | Husqvarna Zero Turn Mower Z5426
My D-7 will not power up...when turn it on the power light weakly flickers (as well as the power sound) for only sec then nothing. Have cleaned battery connections, used charged batteries and even to
Sounds like electrolytic capacitor dried up needs curing, which is power on capacitor and left it absorb some moisture in humidity on power. Some time a few minutes, hard cases may take a few days.
Feb 08, 2012 | Konica Minolta Cameras
Gas getting into oil
sounds like the float in the carb needs adjusted.it will happen if it sits for a long period of time,but id get it fixed because the gas dilutes the oil and decreases the viscosity and could harm the engine.or you could turn the gas off at the petcock as i do on my fourwheeler which has the same problem.
Mar 30, 2010 | Boating
I have a cub cadet LT 1045 and every so often the blades will stop cutting even though it remains in the engaged position.
There are a few possibillites: a bearing is starting to go on the quill assembly or idler pulley; the PTO on the engine is heating up and quitting to work until it cools off; or you may have a switch going bad. I would look at this first.
HTH
Good Day
Nov 10, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Swisher Mower dying when cutting
I've had a 60" Swisher finish cut (13.5 hp) for about 7 years and have found that the valves have to be adjusted on a VERY regular basis. When they get out of adjustment you can hear the starter trying to spin the motor but can't. I'm almost positive this is your problem. Go to You Tube to see how to adjust the valves to .004. It's simple. Stan Wilhite
Aug 17, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
I have a john deere STX-38 Riding mower that keeps draining the battery and some times it wont even turn over "just goes click" thats it!!!
Many of the newer riding mowers slowly drain the battery due to the electronic components. The best way to prevent the battery from draining down in between uses is to install a battery disconnect switch. It only takes a few minutes to install and once it is installed it only takes a simple turn of the knob to disconnect the battery and prevent the battery from draining down. Most major automotive parts stores have them in stock. You can also get one from a mechanic shop whom may have greater access to auto parts.
If you can't find a battery disconnect switch, simply disconnect the negative terminal from the battery when not in use.
Hatter1
Apr 30, 2009 | Garden
My dryer is acting weird
your dryer motor is no longer strong enough to turn the drum,how old is the dryer?mike
Apr 04, 2009 | Kenmore Dryers
Car will not start after it sits a couple days
what car is it ,it could be a cold start sensor/ coolant sensor
Feb 23, 2009 | 2005 Nissan Altima
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
