Mertz washing machine, flashing F02 and not draining.
  • 172 Answers
SOURCE: Kenmore Elite - F02 trouble
Hi jbll,
The f02 code is always from a slow drain issue. This washer allows only 8 minutes for all the water to drain and if it is not gone in time you get the F02.
This is the proper check sequence for that problem.
Check the drain hose and make sure it is not plugged or kinked.
Check the electrical connections at the pump and make sure the pump is running.
Check the drain pump filter for foreign objects. You can remove this easily and replace it if needed.
If the above does not correct the problem, replace the pump.
I hope this has helped, Lots of luck . Mike Anderson
mca0824@aol.com
Posted on May 02, 2008
  • 1028 Answers
SOURCE: No Drain light flashing on washing machine
ckd for something stuck in pump newer models have a low torque electric pump easily stalled by lint or even tooth pick
Posted on Jun 02, 2008
aborcass
  • 2651 Answers
SOURCE: kenmore HE flashing code F02...not draining. help.
no noeed to clean that justyet, i would imagine that the blockageis in the pump housing itself, you can gain acess to this by removing the lower panel of washer and unscrewing the "button trap"
Posted on Jan 26, 2009
SOURCE: Baumatic BTWM6 washing machine flashing F02 error
hi, you need to empty the filter, ours does the same all too often. The filter is located bottom right of the machine at floor level, which is rather daft for an integrated applicance; we have to remove a whole length of plinth to empty ours. Be warned, a lot of gunge and water will come out so have towels at the ready, especially if you have a laminated floor. Turn the white slot with a a 10p piece......and empty. Not the most pleasant of jobs, but effective. Good luck!
Posted on Mar 18, 2009
JULIANFIX
  • 975 Answers
SOURCE: Front loader with F02 problem
CHECK THE DRAIN MOTOR PUMP it could be clogged, need to open washer , locate drain motor , youll see the drain hose connected to it , inspect , clean and replace , AJ
Posted on May 18, 2009
It doesn't finish the cycle and stops and flashes F02
Possible that the drain cycle is not active and so the program trips off. Check the drain for clogging , check the power to the drain from the controller during the cycle, if there is no power the program controller is faulty.
Jul 02, 2012 | Baumatic BTWM4 Front Load Washer
What does it mean when a duet front loader washing machine flashes F02?
f02 mean that the drain time is to long check the drain pump filter that is behind the lower front panel
Sep 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not wash complete load. flashed f02, water not draining
F02 stands for long drain
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
you can press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
you might want to check..
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem most probably you will have to replace the pump
Jul 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F02 error
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If the above does not correct the problem replace the pump
Mar 25, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Getting an 02 F flash
F02 Long Drain
Potential Causes
Aug 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore HE3 front loader keeps getting F02 error message, most often when I wash towels. I was able to workaround by pulling half the load, but that no longer does the trick.
Long Drain
F02
Potential Causes
Jul 13, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F2 is flashing, still in wash cycle
Potential Causes
Apr 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F 02 code is flashing
F02 indicates "Long Drain"
Potential Causes
Jan 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control panel flashing F02
the water in your drain pump is still forzen...its taking to long to drain...ckeck drain hoses too...onthejob
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
