Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Sounds like an alarm going off
I have a whirlpool fridge freezer sounds like an alarm going off its set at-21 then it goes = frezzer isnot holding tempthen when i try to press the +or the - it wont let you do it can you help please
    Problem Solver:
  • 14 Answers
Sounds like you need a new thermostat installed
Posted on May 08, 2009
Have you tried to unplug the unit...wait a few minutes and plug it back in?
Posted on Apr 23, 2009
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
Frezzer not cold enough
Cold originates inside the freezer. TA fan pushes the freezer air into the fresh side. So... if that fan ain't working or ice is built up inside the freezer then the freezer will work but the fresh side will suffer. If you have a defrost problem you could find out real easy. Just unplug it and wait a while (depending on how bad it is iced over you might need to go a few days). Plug her back in and if it works ok for a few weeks but does the same thang again then you have a defrost problem. The defrost system has 3 components defrost timer/control defrost heater and defrost termination thermostat. Why do we need a defrost termination thermostat you say? The defrost length is 21 minutes. if that heating element were to stay on 21 minutes your goose would be cooked instead of defrosted. The termination thermostat is designed to shut down the heater when the temp inside the evaporation compartment reaches 50f. So what goes wrong? Timer hangs up electronic control takes a dump, heater goes bad, Termination thermostat goes bad. Number one component that goes out? Termination thermostat. Look for swelling.
Dec 21, 2012 | Dryers
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
Whirlpool WBM39MW alarm when door opened
Just had one of these with the blinking light, fan pulsating and no cooling. The fault is the power supply section in the control module at the back. It is a 2uF 400VAC capacitor going open circuit. make sure you replace this capacitor with something equal or better rated - it is critical
Jun 17, 2012 | Whirlpool Refrigerators
My whirlpool frost free fridge freezer's alarm keeps going off, ice-cream doesn't freeze?
Check condenser is clean, fans working, thermostat set correctly, try to check internal temp with digital thermometer
May 17, 2012 | Refrigerators
Alarm is going off how do I stop it
The best temperature is the midpoint. Typically 3 or 4. The alarm will go off once the temperature goes down to the freezing point.
May 05, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Fridge part is not cooling well
You have a blockage in the system. Need a technician to come and replace the drier and regas system. Will run correctly after that.
Sep 18, 2009 | Whirlpool ET1FHTXM Top Freezer...
I have a Whirlpool side by side fridge freezer (brand new only 2 days old) the alarm is going off and the two lines side by side on the freezer side are flashing?
The alarm is set off when the freezer is out of the differential range of the setpoint. In other words, the freezer is still too warm. If you press the alarm button, the sound will stop but the light will stay on. If the unit is working correctly and cooling properly, this light should go out once the cabinet temperature gets close to the setpoint temperature. Hope this helps you.
Mar 04, 2009 | Freezers
New Sanyo Fridge not working
I have the sam eproblem but my freezer is very cool, but the fridge wont get cold, it is just chilled, my food still goes bad and the water and soda is room tem..this doesnt make sense!
Nov 25, 2007 | Sanyo SR-1030W Top Freezer Refrigerator
Fridge freezer not cooling from new - buttons not working
Sounds like an air flow problem from the freezer section to the refer section. Check that nothing is blocking the air vents, and that the dampers are operating properly (they control the flow of air). Of course if it's under warranty... call the service techs out.
Oct 27, 2006 | AEG S75578KG Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
281 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
