Question about RTO Farmtrac 8075 Cab And Air Tractor
How to remove starter from 1999 Farmtrac 60 - RTO Farmtrac 8075 Cab And Air Tractor
Mercury mariner 2 stroke 60 hp starter motor removal problems
there are 2 clamps on the starter , top and bottom 2 bolts in each ! isolate the battery then disconnect the wires off the starter and remove the clamps and starter should come off !
Mar 09, 2015 | Boating
How to replace STARTER ON A 1999 KIA SEPHIA
Remove bolt holding main wire from battery. Remove nuts holding smaller wires to starter relay, remove starter mounting bolts then remove starter.
Sep 05, 2013 | 1999 Kia Sephia
Location of "starter" for 1999 cadillac catera
Hi, if you have the 3.0 liter engine, see instructions below. If you have the 4.6 liter, the starter is under the intake manifold.
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove or disconnect the following:
    Negative battery cable Starter electrical connectors Right hand catalytic converter Right side engine mount nuts Intake air resonator to the throttle body ducts
  3. Install an Engine Support Fixture to the right side of the engine.
  4. Raise the right side of the engine approximately 1.5 inches (38mm) to gain access to the starter motor bolts.
  5. Remove or disconnect the following:
    Engine mount from the bracket and cradle Engine mount bracket bolts and reposition the bracket Starter motor
    Fig. Remove the starter motor and bolts
To install:
  1. Install or connect the following:
    Starter motor. Torque the bolts to 44 ft. lbs. (60 Nm). Engine mount to the bracket and front crossmember. Torque the bolts to 30 ft. lbs. (40 Nm).
  2. Lower the engine into position and make certain that the mount locator tab is fully seated in the front crossmember slot.
  3. Remove the special tools from the engine.
  4. Install or connect the following:
    Engine mount nuts. Torque the upper nut to 30 ft. lbs. (40 Nm) and the lower nut to 41 ft. lbs. (55 Nm). Intake air resonator to the throttle body ducts Catalytic converter. Torque the bolt to 25 ft. lbs. (34 Nm) and the nuts to 18 ft. lbs. (25 Nm). Starter electrical connectors. Torque the battery cable nut to 115 inch lbs. (13 Nm) and the starter solenoid nut to 35 inch lbs. (4 Nm). Negative battery cable
Oct 03, 2011 | Cars & Trucks
I need to replace the starter on my 1999 Kia Sephia and I would like to do it myself because I can't afford the mechanics bill.
This starter changes just like most starter. 3 bolts and remove the wiring. Make sure to disconnect the battery first before starting the repair. It is pretty straight forward with any starter removal. Here is an excerpt from someone who made the same repair
"I removed the Air Intake tube. I also removed the battery and put it on
the side! One the right side of the engine, from above I was able to
remove 2 of the bolts holding on the starter. I then jacked up the car
and was able, with considerable gymnastics, to remove the bottom bolt.
Point - Only use a 14mm wrench or socket. From back on top, I was able
to slide the starter to the right and remove the power cable and the
solanoid cable. Down at the NAPA Store in my town, they put the old
starter on the bench and it failed 5 out of the 6 tests! I picked up a
new one - minus the $60 core charge, for $105 with tax, put it in and
the car starts like a dream. Total time for this amatuer; 3 hours."
http://www.mombu.com/asian_cars/sephia-forum/t-2000-kia-sephia-starter-replacement-740894.html
Thank you,
Lee
Aug 19, 2010 | 1999 Kia Sephia
How to Replace the Starter in a 1999 Pontiac Grand
starter is located on the engine block down below.
Removal & Installation To Remove:
Before servicing the vehicle, refer to the precautions in the beginning of this section.
  1. Remove or disconnect the following:
    • Negative battery cable
    • Radiator lower air deflector
    • Torque converter cover
    • Electrical connections from the starter
    • Starter motor
To Install:
    • Starter motor and torque the bolts to 32 ft. lbs. (43 Nm)
    • Starter solenoid BAT terminal
    • Starter solenoid S terminal
    • Torque converter cover and torque the bolts to 89 inch lbs. (10 Nm)
    • Radiator lower air deflector and torque the bolts to 15 ft. lbs. (20 Nm)
Starter removal/installation – 3.1L & 3.4L engines 9306zg15.gif
Starter removal/installation -3.8L engine 9306zg17.gif
Jul 15, 2010 | 1999 Pontiac Grand Prix
How do you remove a 1999 Nissan Altima starter?
Nissan Car Altima & Sentra 1999-06 StarterRemoval & Installation
    Negative battery cable Air duct Harness protector from the harness Starter wiring at the starter Starter-to-engine bolts Starter from the vehicle
    Fig. Starter location and mounting detail-3.0L Maxima with a manual transaxle
    Fig. Starter location and mounting detail-3.5L Maxima
To install:
    Starter and torque the long bolt to 57-72 ft. lbs. (77-98 Nm) on Altima and Maxima and 41 ft. lbs. (55 Nm) on 350 Z. torque the short bolt to 22-30 ft. lbs. (30-41 Nm) Starter wiring Harness protector Air duct Negative battery cable
    Negative battery cable Air inlet tube Harness bracket Wiring at the starter Starter
To install:
    Starter and torque the bolts to 60 inch lbs. (7 Nm) Starter electrical connectors Harness bracket Air inlet tube Negative battery cable
1.6L & 2.0L Engines
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
    Negative battery cable Wiring at the starter Bolts attaching the starter to the engine Starter
To install:
    Starter and torque the bolts to 70 inch lbs. (8 Nm) Starter electrical connections Negaative battery cable
1.6L, 1.8L & 2.0L Engines
  1. Before servicing the vehicle, refer to the Precautions section.
To install:
    Starter and torque the bolts to 70 inch lbs. (8 Nm) Starter electrical connections Negative battery cable
1.8L & 2.0L Engines
To install:
2.4L & 2.5L Engines
To install:
2.4L Engine
To install:
2.5L Engine
    Negative battery cable Air cleaner cover and duct Harness bracket Wiring at the starter Starter
To install:
3.5L Engines
    Negative battery cable Air cleaner case (upper) and air cleaner to electric throttle control actuator tube. Harness protector from the harness Starter wiring at the starter Starter-to-engine bolts Starter from the vehicle
    Fig. Starter location and mounting detail-3.5L engine
continue...
Apr 05, 2010 | 1999 Nissan Altima
1999 GMC sonoma starte installation
2.2L Engine remove protective shields as needed then remove front exhaust pipe. Remove the brace from the engine to the clutch housing, then disconnect starter wiring. 4.3L Engine 2 wheel drive just remove the right front tire and you will have access to the wiring. 4.3L Engine 4 wheel drive you must remove the differential carrier shield if equipped then remove the starter bolts and rotate the starter to get access to the wiring. Good Luck.
Jun 15, 2009 | 1999 GMC Sonoma
How to change my starter on a 1999 Chevy P10 Step Van
Remove the negative cable from the battery.
Remove wires off of starter.
Remove 2 starter bolts.
Reuse shims that may be installed.
Replace the starter in reverse order.
Jun 09, 2009 | 1999 GMC Sonoma
Replacing a starter for a 1999 Altima
  1. Disconnect battery ground cable.
  2. Disconnect starter wiring from starter.
  3. Remove starter retaining bolts and the starter.
  4. Reverse procedure to install.
the bolts should be on the drivers side.
you will have to crawl underneath the car to do this task
May 15, 2008 | 1999 Nissan Altima
RTO Farmtrac 8075 Cab And Air Tractor Logo
50 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
