Question about Emerson Evergrind E202 1/2 HP Garbage Disposer
We installed the Evergrind E202 - it did not come with a manual and now our dishwasher won't drain....
Garbage disposal quit working. Just stopped
Press reset button located on bottom of unit.
Use broomstick down inside disposal to make sure cutter disc rotates freely.
Copy following link for troubleshoot and illustrations:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
h
Aug 19, 2013 | Emerson Evergrind E202 1/2 HP Garbage...
Leaking garbage disposal
1) Where is the leak coming from?
Copy following link for troubleshoot walk thru and replacement tips
2) Add a comment Feb 2013
Feb 10, 2013 | Emerson Evergrind E202 1/2 HP Garbage...
How do you winterize Model GE20P06SAG? There is no drain at the very bottom...?
Thank you for including model number for EZ identification of water heater
To drain tank without drain valve: Remove TP valve at top of tank and siphon out the water. Then reinstall with correct pipe configuration shown in product manual.
Product manual shows drain valve is not supplied with this unit.
http://waterheatertimer.org/pdf/GE20P06SAG-under-counter.pdf
Product manual shows the Installer should add both shut off valve and drain valve on cold water inlet line.
http://waterheatertimer.org/images/GE20P06SAG-under-counter-60.jpg
More resources:
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Sep 30, 2012 | RELIANCE 19.9 Gallon Electric Compact...
Emerson Evergrind E202 1/2 HP Garbage Disposer Logo
Top Emerson Water Heaters Experts
Donni Steen
Gil Shultz
ray gallant
Are you an Emerson Water Heater Expert? Answer questions, earn points and help others
