Question about Uniden Radio Communications
Wiring diagram for uniden uh015sx uhf radio mic
2 Suggested Answers
  • 773 Answers
SOURCE: My Uniden uh015sx uhf cb radio only has about 50m range.
that's pretty far. I would say the problem lies in your antenna. Is it tuned properly? Is it up high? Are there hills around you blocking your signal?
When it comes to distance, height is might. I have seen bare foot 4 watt radio get more range then your radio. Its all about the antenna system.
Posted on Apr 06, 2010
Where can I get a Circuit Diagram for a Uniden UHF 012sx UHF CB Radio?
The only place you would get that is from Uniden themselves.
UHO12SX Manual - Uniden
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/UH012.PDF
UNIDEN Model uh012sx UHF CB Radio. Contents. Introduction. 2. Features. 2. Preventative Maintenance. 2. Troubleshooting. 2. Controls/Connectors. 3. Missing: diagram ‎012sx
[PDF]UH8060NB - Uniden
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/UH_8060NB_OM.pdf Operating the UHF CB Radio in Duplex Mode. 17. Scanning ... The Uniden UH8060NB is designed to provide you with years of trouble ... Built-in AVS Circuitry†.
[PDF]UHO12SX Manual.cdr - Uniden
https://www.uniden.com.au/RESOURCES.../uhO12SX_OM_2yrWarranty-Updated.pd... UNIDEN Model uh012sx UHF CB Radio. Contents. Introduction. 2. Controls/Connectors. 3. Indicators. 4. Included with your uh012sx. 5. Operation. UHF CB ...Missing: circuit ‎diagram ‎012sx
Circuit Diagram for Uniden UHF 012sx Google Search
Mar 19, 2017 | Uniden Radio Communications
My uniden uh015sx wont recive but will transmit ' new antena new antena wire and have swoped hand piece still same
First proceed with manual programming steps using squelch/volume knob. Second search for local tech service.
Dec 03, 2015 | Uniden Radio Communications
I pulled u uhf out of my vehicle and replaced it with a pro 520 xl uniden uhf but it won't work.
Check your electrical connections and your antenna set up first. Then if you still have a problem, check your mic/mic plug. Lastly, check your programming. If you have ignition sense programmed into the radio you will need to wire it accordingly, so it will sense the ignition of the vehicle.
Best regards.
Sep 13, 2013 | Motorola UHF 1-Watt, 1-channel Radio
Uniden uhf 15sx radio how to wire up
Hi,my name is John. The other red wire is positive also, and the black is the negative or ground wire......hope this was helpful....Rate this on the four thumbs-up.....John
Jul 18, 2010 | Uniden Radio Communications
I have Uniden uh015sx radio and I can't program scanner
This Australian model CB/scanner operates in the UHF band only. Frequency coverage for the scanner function is 400-512MHz. Need the operating manual? You can download/print it here:
http://www.uniden.com.au/resources_main/pdfs/uh015sx_OM_2yrWarranty-Updated.pdf
Bill B
May 12, 2010 | Radio Communications
My Uniden uh015sx uhf cb radio only has about 50m range.What could be wrong?
Apr 04, 2010 | Radio Communications
This is a UHF only radio, with coverage from 400 to 512 MHz. Need the operating manual? You can download/print it here:
http://www.uniden.com.au/RESOURCES_MAIN/pdfs/uh015sx_OM_2yrWarranty-Updated.pdf
Bill B
Mar 20, 2010 | Radio Communications
Mic hum
Yes, the wiring is different. Reverse the wires on pins 1 & 2, then reverse the wires on pins 3 & 4.
The wiring for you radio's mike is:
1- Audio
2-Ground (Shield)
3-Receive
4-Transmit
Depending on the vintage of your mike, the colors Uniden uses for these functions are white or yellow for audio, red is transmit & black is receive.
Jul 31, 2008 | Superstar SS-121 120-Channels Base CB...
Mic wiring diagram
Want to wire cobra mic to a uniden washington radio
Nov 20, 2007 | Radio Shack TRC-447 CB Radio
Radio Communications Logo
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
