Question about N2 HT221, Robin 24" Hedge Trimmer
I have a problem starting my robin hedge cutter ,it's sparking poured fuel down ,were the plug sits still not starting ?
I have a Stihl FS160 Brush cutter that will not start. The compression is 900kpa the spark plug is new with plenty of spark. When removing the plug after trying to start the plug is wet. If I dip the plug...
Could be a number of problems. 1-check timing gap between flywheel and ignition module 0.25 feeler guage. 2-fueling issue, over fueling/under fueling. Check needle valve in the carb isnt sticking in the seat. check diaphrams aren't fatigued.
Mar 04, 2015 | Garden
How can I get a replacement spark plug for a Rolson hedge cutter ???
While I'm not familiar with your brand, IF you want to CHANGE the spark plug, then simply REMOVE the current plug from the machine, take it to ANY shop that sells spark plugs [any auto part supply], and/or lawn equipment, and using the numbers ON the old plug they can find a suitable replacement plug!
Aug 26, 2014 | Garden
Stihl fs80 hard to start and will not run at power
I would check the spark arrestor screen in the muffler. They are known for plugging up and causing serious running problems.
Aug 15, 2010 | Oregon Scientific Complete Carburetor for...
Stihl Gas hedge trimmer will not start after sitting idol for some time (4 months) with gas in ti.
Purchase a new spark plug. Pour all the fuel out of the tank and fill it with a fresh supply of fuel. Now, remove the spark plug and spray a small amount of carb cleaner in the combustion chamber. Quickly install the spark plug and fully close the choke, press the primer button 3 times and try to start it. You may have to do this several times until it starts and runs.
May 31, 2010 | Garden
Stihl 011 av wont start
Flooded? Try a new plug, or get that one cleaned up. If it is sparking and wet, it should fire, even if it doesn't run, it should spark. Did you put the jets or the needle valves back to where they were? I think they start out at 1 1/4 turns out , then adjust the low and high. If it is fouling out with too much gas, the low speed jet is open too far.
May 07, 2010 | Oregon Scientific Complete Carburetor for...
Stihl saw TS400 will not get fuel through,NON START
how much fuel can be put into a stihl saw ts 400 and how long will the fuel last while in constant use
Mar 24, 2010 | Oregon Scientific Complete Carburetor for...
Mcculloch Virginia hedge cutter manual
mcculloch virginia mh542 hedge trimmer, fires 1st time, will only tick over roughly on full choke only then stalls when throttle applied, I have fitted new plug'cleaned air filter and new fuel mix but no change.
Nov 25, 2009 | Garden
My stihl fs 350 wont start at all now i bought new air filter petrol filter and spark plug kit, still no luck, i messed about with the one screw on the carb so much i dont know where it is supposed to be...
if your fuel was bad, you have oxdashion in the sys. check your spark and compreshion. no less than 78pds if all is good, RR carborator over haul it, no if and or buts. this is an EPA Carb. flush tank line carb and get the oxdashion out. set each screw to 1 to 2 turns out and adjust the idl frist than the high side at full throttal untell engine smothes out
Oct 11, 2009 | Oregon Scientific Complete Carburetor for...
I have an tht200 hedge trimmer that has been sitting a long time. Added fresh fuel and tried to start but will not fire at all. Any ideas?
give it a tune up ... check the mag, probably have to rebuild the carb ... new plug ... You must get it to spark.
Oct 08, 2009 | Tanaka Hedge Trimmers: 20" Dual - Sided...
My stihl fs 350 wont start at all any sugestions ?, thanks from mark uk
I would have a shop do a compression test on the engine. It should be at least 100 psi to run. And then a spark test on the ignition module to see if it firing to the spark plug. I would look at a carburetor rebuild. I would also mix up some fresh fuel mixture; anything over 30 days now is considered bad gas.
Sep 30, 2009 | Oregon Scientific Complete Carburetor for...
N2 HT221, Robin 24" Hedge Trimmer Logo
61 people viewed this question
Top N2 Garden Experts
Dennis Key
Dennis Key
john h
Are you a N2 Garden Expert? Answer questions, earn points and help others
