Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
MY FURNACE STARTS UP IT SOUNDS LIKE IT'S GOING TO IGNITE BUT DOESN'T NO FLAMES JUST BLOWS COLD AIR IN THE ROOM PROBLEM???
If u want to do it ur self open it and paper sand the thermocouple gently then try again
Posted on Apr 23, 2009
My furnace works on ac and blows on ac but on heat it does not blow but i hear a humming sound coming from the furnace
Most furnace operating on Oil or gas will heat the combustion chamber before starting fan to prevent cold air draft at start-up, can last a minute or two. Eiter the main flame does not come on or the chamber thermostat have fail. Try to modify fan option on room thermostat from auto to on. Cold air coming out: burner problem or no more oil or gas, warm air: burning chamber thermostat problem, leave room thermostat fan option to on until repair.
Jan 02, 2014 | Comfortmaker Heating & Cooling
My dehumidier blows very hot air while working. Makes it hotter than it was before starting. Like a furnace.
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in.
You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
Jun 26, 2013 | Windchaser WDH928 Dehumidifier
Amana gas furnace,air command 80 sv. does not ignite blows cold
Hi check out the pressure switch jump it out and see if it lights also check the igntion coil is glowing
Feb 09, 2010 | Heating & Cooling
My furnace heats the house well, but during the cool down it actually blows cold air dropping the temperature causing the furnace to re-ignite. How do I adjust? Goodman - GMS9/GCS9
Depending on the age of the furnace you may be able to adjust the cool down. On some furnaces there is a silver box usually made by honeywell. This is your fan limit control. If you take the cover off you will see a dial with different temperature settings with 3 pins in a grove. The first one is fan on with temperature rise this turns the blower on when the furnace starts and warms up. The second is the fan off after furnace shuts down, this would be the one you want to adjust to a higher temperature to keep the blower from blowing cold air. The last pin is the high limit if the furnace gets to this temperature it will shut the furnace off but keep the blower running. Make sure that the thermostat fan option is set to auto and not on.
Jan 02, 2010 | Goodman GMS90703BXA Heater
Furnace blowing cold air
Hello , I think I can help , It sounds like the gas valve as long as your sure there is plenty of gas going to the unit and you have an electronic ignitor , if there is a pilot light its not electronic. the gas valve should come as an assembly to install and its pretty easy to complete. Let me know if you need more help. Good luck
Dec 22, 2008 | Intertherm P3RA-048K Air Conditioner
My Heater blows cold air
is this a gas furnace if so does the burner ignite
Nov 25, 2008 | Intertherm P3RA-048K Air Conditioner
Will not ignite properly
If you look at the wiring diagram in your furnace you will see that 4 blinks means there is either a blockage of air or your room air blower is not working. Check the air filter for any debris first. Then test the room air blower to see if it turns on and blows enough air prior to going out on code. Are all the dampers open both in the pipes as well as at the registers?
Oct 14, 2008 | Goodman GMS90703BXA Heater
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
66 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
