Question about Dimplex Compact Electric Flame Stove Heater
My dimplex club 2 kw model number clb20r keeps cutting out after being on for a while any idea what I can do to fix this
2 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: Anyone know where I can buy part number
Some hardware stores, electrical supply stores, radio shack, are a few places I would think of trying. Take old one with you to make sure same amperage/voltage rating.
Posted on Oct 04, 2011
Can i change wattage on my dimplex fire place model dfb 8842
This model does have 2 elements and it will likely cut the wattage in half if you disconnect one. Not sure how hard it is to get to the heater assembly, but there are terminals on the right side that probably have spade disconnects. If so, remove one marked D or E, and tuck it away and see if it puts out less heat.
Dec 19, 2015 | Dimplex Heating & Cooling
Dimplex club heater flicks on/off either on manual or using remote
It sounds like a dodgy thermostat or thermistor to me. When a thermistor goes wrong it can cause what is known as rapid-cycling in a heater, where the unit will keep switching on and off, on and off repeatedly.
May 28, 2014 | Dimplex Compact Electric Flame Stove...
I need new light bulbs for my Dimplex Charlotte Optymist fire Model number CRT2OAB where can I get them
The model you have uses a different set of bulbs, than Dimplex's other models. So, you'll need to Contact Dimplex USA, Technical Service Dept @ 888-346-7539. I'm sure they can help you.
Mar 22, 2011 | Heating & Cooling
Where can a fuer dbg 2-5w 230v ac 50hz 15rpm motor which operates the flame effect on my dimplex fire be purchased
You can buy it directly from the Dimplex USA website. Make sure you have your Model Number handy.
Feb 16, 2011 | Dimplex Compact Electric Flame Stove...
I have an old RITZ/Club Stove electric fire, model CLB20L. The fibreglass log effect panel has started to break up. Is it possible to purchase a replacement for this?
Depending on how all it is you may or may not be able to. Go to the Dimplex website and contact their Customer Service Dept.
Jan 25, 2011 | Dimplex DS5603 Heater
Why does my dimplex model bf8000st fan and heat turn off after 2 or 3 minutes? the flame lights keep working, just no fan or heat.
"Resetting the Temperature Cutoff Switch
This unit is equipped with a thermostat which controls the temperature
of the room by turning the heater on and off. The heater is protected
with a safety device to prevent overheating. Should the heater
overheat, an automatic cut out will turn the heater off and it will not
come back on without being reset. It can be reset by switching the
Main On/Off Switch to off and waiting five (5) minutes before switching
the unit back on."
http://dimplex.com/cms/publications/7208680300r03_EN.pdf
Dec 13, 2010 | Heating & Cooling
My dimplex night storage heater has stopped working.
...not too sure of your model but all dimplex heaters to my knowledge have an 'overload' cut out built into the system. Ours is more up to date but still goes now and then, problem is you have to get into the electrics and click the reset button, normally near or on the thermostat it's self, could be a small white plastic button, or a piece metal sticking up that needs pressing down to reset...but please before attempting make sure that you TURN OFF THE ELECTRIC / REMOVE THE FUSE/ WHAT EVER IT TAKES TO CUT ANY CHANCE OF AN ELECTRIC SHOCK!!!...because I can and will get you if it can ;-)... if your not a competent electrician please get hold of one !... good luck.
Feb 01, 2009 | Dimplex Heating & Cooling
Dimplex FXL24n wont heat up over night
the clip should click and the heater reset its self have you repalaced the clip ? some times you have to press the clip hard to get it to click
Nov 26, 2008 | Dimplex DS5603 Heater
Dimplex Compact Electric Flame Stove Heater Logo
103 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
