Question about Toshiba Satellite 2455-S305 Notebook
Getting vertical lines on the screen - Toshiba Satellite 2455-S305 Notebook
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
How to fix LG TV Vertical lines.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 30, 2015 | LG 47LA6200 47" 1080p 3D Smart TV 120Hz...
Vertical line complant
This is not the vertical line complaint. It is vertical retrace line on screen problem. Might be and IC fault [main chroma] or improper screen voltage. In rare cases this might be of a faulty video output transistor. Anyway, vertical retrace lines are visible on screen, is the problem. If you wish to get more details abut this, just visit the site linked here. Type in " My service table today" as key phrase, in the search box; can be located at the top right of the display window. You'll get an idea about how to proceed.
Look into all gathered posts.
Jun 19, 2015 | Televison & Video
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
Why my t.v screen is one inch less from down side?
Vertical scan output section circuit fault.
Visit this site to get more details.
Feb 19, 2015 | Televison & Video
White vertical lines like jail bars
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 26, 2017 | Samsung HLN5065W 50" Rear Projection...
Dell 1720 screen
If you can see the vertical lines during POST, try to check the vertical lines in BIOS. If the vertical lines are there in BIOS, the only thing you can do is to replace your LCD screen.
Oct 31, 2009 | Dell Inspiron 1720 Notebook
I have vertical colorful lines on the screen just got a new computer with windows vista
the monitor is bad if your getting vertical lines on it. Anytime you get vertical lines on any monitor, LCD, laptop LCD, etc, then that means the screen is bad.
Your monitor needs to be replaced.
Aug 09, 2009 | Envision Computers & Internet
Green vertical lines on panasonic viera screen
I have two vertical very thin green lines on TV how do I fix
Jun 26, 2008 | Televison & Video
Toshiba Satellite 2455-S305 Notebook Logo
135 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
