How do you put the IP address on a epson tm c3400?
2 Suggested Answers
SOURCE: What is the IP Address for Epson TM- U220PD
If you have the same model, on the back of the printer next to the ethernet port is a little button/ hole. Push and hold that down for a couple seconds until it starts printing. It will print out the IP address. Manually assign your computer to have an IP address in the same range (I.E. if the printer says 192.168.1.23, set your computer to 192.168.1.29 with the same subnet mask, etc.). Plug a network cable from your computer directly into the printer. Then, you can change the settings.
Posted on Mar 04, 2010
Epson tm u220b manual feed works, autofeed does not work
Probably the rubber sheet pick up "fingers" have hardened over time and are unable to grip it. This is a common autofeed problem.
Nov 03, 2016 | Epson Office Equipment & Supplies
Tip
Steps to Configure Static IP Address for Epson Wireless Printer
The IP address is a specific number allocated to a device, which is connected to your PC network. If you require configuring a static IP address for your Epson printer, it can be possible by using the network configuration menu that you can access via the Internet browser on a connected system. To do that, it's necessary to know your printer's existing IP address. If you have a password protected the device, then you must know the username and password credentials to access your Epson printer network configuration menu. You can call at the Epson Printer tech support phone number and get expert's assistance to do that in a proper way.
Find Epson Printer's IP Address
    1.Click the 'Windows Start' button and choose the 'Control Panel' on any system connected to the similar network as your Epson printer.
    2.Double-click the 'Printers and Faxes' option and then find the Epson printer that you want to configure a static IP address for in the printer list.
    3.Right-click on the Epson printer from the list and choose the 'Properties' option.
    4.Click the 'Ports' tab and find the printer to configure a static IP address. Click on the printer to select it.
    5.Click on the vertical bar between Description and Port and shift it to the right to expand the Port column. Find the Epson printer's IP address under the 'Port' column, which is a series of numbers divided by, resembles and periods 192.168.1.2.
      1.Open up your favorite Internet browser on the system connected to the similar network connection as your printer for which you need to set up a static IP address.
      2.Input the printer's IP address into your browser address bar. Click the 'Enter' button.
      3.Enter your printer login information. If it's not password-protected, enter 'admin' text into the 'Username' box and leave the password field vacant. Click the 'OK' button, followed by the 'IP Configuration' tab to sign into the Epson wireless printer settings page.
      4.Find the 'IP Address Configuration' or 'TCP/IP' section and adjust the value from 'Auto' to 'Manual' or 'Static.'
      5.Input the static IP address that you need to allocate to the Epson wireless printer into the provided boxes. It forces the network to assign the selected IP address to the Epson printer every time it tries to connect to the computer.
      6.Click the 'Save' button to apply the settings and close the browser.
      Additional Tips:
      Configuring a static IP address for the Epson wireless printer is not a complicated process if you are a tech-savvy user. However, if you can't set static IP address for your printer even after following these steps, you must avail the help and guidance of technicians that can be possible via the Epson technical support phone number. They will assist you step-by-step to configure IP address of your printer in an efficient manner.
      Source: http://bit.ly/2lJLWxS
configure static ip address for epson wireless printer-yxa4stq55mknsqg0b4p2yanw-2-0.jpg
on Feb 15, 2017 | Epson Office Equipment & Supplies
My Epson Label printer is showing as not connected when its connected, when trying to set up or add as new printer.
What shows mac and ip address ? printer or pc ?
If the printer displays them, it means the printer in connected to router electrically.
Check subnet mask and gateway address.
Could be set wrong if the router is not on DHCP.
I guess the issue is in the ethernet components / settings.
Start isolation by elimination of the following
1. Computer -
2. Wifi connection to the router (or)
3. Patch cable connecting computer to the wall -
4. Router -
5. Patch cable connecting the printer to the wall -
6. Printer -
The LAN printer cannot connect to Computer (PC/Mac) directly unless you use a Cross over cable.
Sep 11, 2016 | Epson Tm C3400 Securcolor - Label Printer...
Dip switch settings for Epson TM U210D printer
I put the page you need up on my server.
http://www.itrsva.com/TM-U210-DIP_Switches.pdf
Jul 25, 2011 | Epson TM U210D Matrix Printer
I need the printer driver for epson thermal printer TM-T88111P
You can try downloading from this site which requests you provide your e-mail address or you might prefer to send a request for the driver directly to the manufacturer.
See here for details on your printer:
http://www.epson.com.au/businesssystems/products/receiptprinters/DisplaySpecs.asp?id=tmt88iii
Click on Technical & Support along the top menu bar. This will bring up a submission form which you can use to submit a request to provide a driver for your printer.
Dec 29, 2010 | Epson TM-T88III Thermal Printer
I have one Epson TMU220PD printer. I have to set its IP address. how can I do it. Also, i want to know its default IP. Thanks, Saket
switch on your printer while pressing feed button.printer will print some pages and u can read ip address of printer in printed page.Then add same ip range in ur computer.connect printer to pc by network cable.test ping command to printer ip address.if ping succes then open internet explorer, type printer ip address in address bar, press enter key..there u can set ip adress from tcp ip options.
Oct 23, 2010 | Epson TM-U220 Matrix Printer
Jun 19, 2009 | Epson TM-U220 Matrix Printer
Unable to establised the IP address of the printer. How do I find out the IP address of the printer?
What operating system are you using and how are you setting the printer on a network? is it connected to a router? did you already download and run the net config utility?
if you are using windows visit this link and download the net config utlitlity
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58603&prodoid=58311371&infoType=Downloads&platform=Windows
if mac
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58603&prodoid=58311371&infoType=Downloads&platform=Macintosh
Update me for issues and difficulties acquiring the ip add
Apr 22, 2008 | Epson AcuLaser CX11NF Printer
jasbo
jasbo
