Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Frigidaire dishwasher model fdb1100rhso won't drain
3 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: won't get dishes clean
Possible that the spraying arms are not working fine and there is less pressure on the pump. If so remove and clean the pump and check the spraying arms specially if the arms are not moving faster.Please check this link for tips to clean:
http://www.espares.co.uk/advice/dishwashers/a/3/1353/dishwasher-cleaning-properly.html
Posted on Mar 12, 2012
Testimonial: "I checked out the spraying arms, it wasn't the problem but it was a good start in troubleshooting the unit. I purchased a new drain pump and installed it. The dishwasher now works as it should. Thanks for the heads up."
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: fRIGIDAIRE dishwasher door won't latch
    Check to see if the door is not aligned correctly anymore, or if the door sags underneath the latch plate and go from there. You may need to adjust the door or replace the latch itself.
    Posted on Jul 24, 2012
    I am trying to locate an owners manual for a Frigidaire Dishwasher model # FGHD2433KW1
    Below is the link, you can download it
    http://www.manualslib.com/products/Frigidaire-Fghd2433kw1-2885301.html
    Dec 05, 2015 | Frigidaire Dishwashers
    Reset frigidaire dishwasher model FDB1100RHC
    I had the same issue. I unplugged the dishwasher and plugged it back in. Bam! It's working fine now.
    Oct 16, 2012 | Frigidaire Dishwashers
    My frigidaire professional dishwasher won't drain
    In the bottom of the unit, do you notice clean or dirty water? Do you have the unit connected in the same drain line as a garbage disposal?
    Aug 31, 2012 | Frigidaire Dishwashers
    Dishwasher won't drain
    Most likely the exhaust selenoid is burned out - or the small metal arm that connect to exhaust valve is disconnectrd
    Jan 05, 2012 | Frigidaire Dishwashers
    After removing the bottom assembly from my frigidaire dishwasher to clean it, I reassembled it and now the spray arm won't work although the machine fills and drains. I found a small white ball in the...
    The ball goes under item 10 this picture:
    http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=381580&pkw_=basket&model_id=5120395&NewWindow=1
    You can enlarge the picture once opened. The Expert Gene Strote was correct. I just like this picture better because you can instantly expand it with explorer.
    Manual Number 5995477345.pdf is a service manual not for your unit but will show you the sump and were the ball goes.
    http://appliancedigest.com/index.php?/files/file/147-frigidaire-fully-integrated-direct-feed-model-dishwashers-5995477345-service-manual/ (registration required)
    A service manual that will show you the sump area and the ball.
    Thanks for choosing FixYa, and myself.
    Kelly
    Jul 30, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
    Water won t drain
    Here is a tip that I wrote that will help you with your dishwasher not draining problem...
    Dishwasher Problems - Water will not drain out
    heatman101
    Mar 10, 2011 | Frigidaire Professional Series 24 in....
    Water not draining fully on dishwasher.FRIGIDAIRE model GLDB653AQ1
    heatman101
    Jan 15, 2011 | Frigidaire Dishwashers
    Brand new first time using it Frigidaire dishwasher not draining has water in the bottom. Model # FPHD2491KFO
    Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
    heatman101
    Nov 23, 2010 | Frigidaire Professional Series 24 in....
    Standing water at bottom of dishwasher. Make and model is Frigidaire Gallery
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
    heatman101
    Sep 01, 2010 | Frigidaire Dishwashers
    Can't find the model number on Frigidaire dishwasher
    The nomenclature should be located on the left side on the inside of the tub right by the front when you open the door. It is most likely an fdb series example fdb1050. however the drain hose pn 154606701 is the factory replacement for most frigidaire dishwashers ten years or less.
    Mar 31, 2009 | Frigidaire Professional Series 24 in....
    Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
    Top Frigidaire Dishwashers Experts
    Mike
    Charles T Nevin
    Charles T Nevin
    Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
