SERVICE MANUAL LUXMAN A357 - Office Equipment & Supplies
Turntable manual for a luxman p-400
Hi, any phono pre amp will do it. The better ones have RIAA with gain control and earth point. Cheers john. Stylus City
Feb 23, 2014 | Audio Players & Recorders
Luxman turntable manuals
Have you tried the Luxman website? Most makers have free PDF's of them.
Will a Luxman R-117 receiver run my Bose 901's through the required equalizer?
Yes, connect the Active EQ into one of the abundant tape loops and set the receiver to monitor that one constantly. Or place it between the Pre Out and Main In's. What you don't want to do is have the Active EQ in front of any actual tape decks attached to the Luxman as it would affect their audio. Yeah, pre/main is the best place.
Jan 31, 2010 | Bose 901 EQ1915 Home Equalizer
Luxman R-115 NEED REMOTE CODES FOR COMCAST ON DEMAND REMOTE
Try a Harmony by logitech. They will control every feature of every piece of product that you have. Prices start around 50 on ebay. The software for programming is excellent and very user friendly. Their tech support speaks to you in understandable language if you have a problem. I've probably programmed a thousand or so to date and they are very reliable. The only issue I have with them is Don't Drop Them on a hard surface, the LCD's are pretty fragile. If you have young kids, keep them away from it!. With a little tweaking in the program, you can have a very reliable and effective remote for very little $. If you get one and have any questions on programming, post a comment and I'm positive I can help. Hope this helps
Jun 22, 2009 | Audio Players & Recorders
Luxman Digit synthesized stereo Receiver AM/FM & Phono not work'g
The problem is still there, but I am expecting HELP fir free.
May 11, 2009 | Car Audio & Video
Blown output drivers
The transistors are 2SK405 and 2SJ115.
I fix Luxman if you dont mind sending to Vermont.
Cheers ( I hope that helps)
Feb 14, 2009 | Alpine Audio Players & Recorders
Owners Manual Replacement
Check out this web site http://www.audiocircuit.com/index.php?c=LUX&cc=940&m=D-351# Looks like they will be able to help you.
Feb 14, 2009 | Classic Electronics Audio Players &...
Luxman LV 105 Amplifier gone dumb
Hi: If the Amp has an audio output transformer, check for bad solder connections to the pc board, This are the wires from the transformer to the PC board. Another place to look is the earphone connection plug. If the jack has a bent contact inside of it, you will have all sound cut off. Good Luck.
Al
Mar 09, 2008 | Carver PM950 Amplifier
112 people viewed this question
k24674
