Question about Mitsubishi LT-46153 LCD TV
Mitsubishi LT-46151 dark wavy screen distortion on right half of screen until the tv is warmed up. once it's warmed up, you can turn off and then turn on and the screen is perfect.
  • 3 Answers
SOURCE: Mitsubishi 40" TV, LT-40134 Vertical lines on left side of screen
I've got the same TV with the same problem. Sometimes by moving it on the stand the lines will go away but it only sometimes temporarily fixes the problem. For a while it seemed like it needed to heat up to go away but that is not the case. It seems like there is a bad connection somewhere but i cant seem to find it. One day, one thing will fix it, then the next day it wont do the trick. It gets very irritating.
Posted on Oct 26, 2009
budmrtn
  • 11361 Answers
SOURCE: 2 year old Mitsubishi LT-46149 46" LCD Flat Panel
Does it come and go? I would try reseting the ribbon cables between the LCD panel and the T-CON board first.
The Flexible Printed Circuit BoardS (FPCB) are ultrasonic welded to the LCD TFT panel, they are not SOLDERED on! The connections do get bad due to very delicate nature of how the LCD panels are made. You can also try squeezing the around the top area of the screen where the lines are to see if the lines go away.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 15, 2010
techman007
  • 1112 Answers
SOURCE: I have a Mitsubishi WS-55313
Hi:
The lines across the screen may indicate one of the picture tubes are or going faulty, depending on what color the lnes are on the screen, The slow start is bad capacitors in the digital control board module inside the set, there is a power supply module inside the metal canaister with bad caps on the board about 6-8 of them needs replacing the value to replace them with is 680uf rated at 16volts. The screen is probably no longer avaiable for purchase any more as well as the picture tubes. If any of the picture tubes fail then I suggest its time to purchase a new more modern television.
Posted on Mar 25, 2011
SOURCE: Can't get sound out of the LT-46151 - mute is not
turned on tv no sound this morning and nothing mute not on worked last night
Posted on Apr 23, 2011
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi WS-55613 55in.
1. "wavy" may mean a signal problem inside the set--are you seeing colors out of position or skewed around letters etc?
2. Does it do it when a DVD is played? (this will rule out certain things).
SD TECH
Posted on Apr 22, 2012
LT-46151 mitsubishi tv, Green light flashes, no picture, back light is on, screen is blue.
If you have any later digital camera or phone with a compatible connector and cable, try connecting this first.
The set may be looking at the wrong input for signal.
Using your remote, check the setup menu to ensure that your source (cable, receiver, etc.) hasn't been accidentally changed.
Often, a blue screen means 'no signal.'
Jun 04, 2015 | Mitsubishi Televison & Video
Hello, I have a Mitsubishi LT-46151. When I power the TV ON I'm getting a blue screen and the GREEN power light is flashing. The blue screen continues to show and then the GREEN flashing power light
Hey it sounds like u have did everything, so check and make sure u downloaded the right firmware on a good USB drive such as a 4GB and make sure format it with Fat32 before u download. Have seen that before with jump drive device and follow directions from Mfg website. If does not work then the CPU or Eprom has been corrupted and main board needs replacing.
Dec 08, 2014 | Mitsubishi LT-40148 40 in. LCD TV
Distorted picture with wavy lines..
SOUNDS LIKE A CAPACITOR GOING DOWN ON BOARD OPEN BK LOOK FOR BULGING HEADS
Sep 28, 2017 | Sony Grand WEGA KF60WE610 60" Rear...
Horizontal wavy lines on picture
Sounds like the convergence has failed. This video gives more details
Apr 12, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Can't get sound out of the LT-46151 - mute is not on.
Jan 19, 2011 | Mitsubishi LT-46151 46 in. HDTV LCD TV
Right side of screen becomes discolored and fuzzy after 15min
if its an lcd, it could be a bad lcd panel
does the menu or volume get distorted or dark too?
yes - likely lcd panel
no - video board (main board) problem
a technician would use a can of "freeze spray" to find the issue inside, by cooling down the parts until the problem goes away.. the part you froze to reverse the issue is the bad part.
Jun 06, 2010 | Televison & Video
Mitsubishi VS-55609 distorted Picture Flickers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
May 14, 2010 | Mitsubishi VS-5059 50" Rear Projection...
Mitsubishi LT-46153 LCD TV Logo
96 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
