Canon pixma mx920,print envelopes
"canon mx920 does not print out envelopes, message says out" -- because it falls within my area of expertise. I just need a few more details about your situation and I will get to work!
SOURCE: PIXMA 830 Smudges when printing envelopes
On my MP780, be careful to select the appropriate paper type; I was getting black smudges on the left side of my envelopes until I explicitly set that my paper type was "envelope" from "plain paper".
Another idea is to adjust the "ink drying wait time" to a higher level.
Posted on Dec 18, 2007
Rain041304
  • 63 Answers
SOURCE: printing an envelope in cs3 on an epson stylus photo r1800
You can try using Microsoft word in printing on envelopes, it is easier. On my MS word>tools>letters and mailings>envelopes and labels>click on feed and use the fourth from the left option.
Load the envelope at the right side of the printer> the envelope flap should be on the left facing the printer.
Posted on Feb 15, 2008
SOURCE: Canon Pixma MP780 "Wrong Cartridge" Error Message
I have two Pixma 780's. After getting the "wrong cartridge" error one day when I turned it on, (I knew it was the right cartridge) I tried switching ink tanks, and the print head cartridge several times between the two printers. the problem followed the black print head cartridge, so I am guessing I need a new one. From that experience, I would recomend swithing the print cartridge if you get this error. Does anyone know how to do a reset on this machine? A Canon tech told me once, but I lost the info.
Posted on Sep 13, 2008
SOURCE: Service error 5100 on my canon Pixma mp110
just replaced the ink cartridges and reset the counters, evrth ok now :-)
Posted on Nov 09, 2008
SOURCE: Print head
I encounter exact same problem. What I did was took out the print head and clean the print head with Qtips with alcohol. To locate and remove print head, follow the instruction at Canon's PIXMA MP830 website and choose the tab "Support & Service" type "rseating the Print Head"
You'll be seeing
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804#SupportDetailAct
Basically, printer head is inner carton where ink cartridges sit.
Above link shows pricicely how to remove the ink cartridge.
Above link's instruction says, Caution: do not touch print head nozzles<1>
But, I just went ahead and clean the print head nozzles with rubbing alcohol soaked Qtips.
After completely cleaned and dried, I reinstalled print head, reinstalled ink cartridges,
closed all the cover. It went back working perfectly.
Posted on Jan 30, 2009
How do I adjust the setting to lighten copies?
Canon : PIXMA Manuals : Print Studio Pro : Settings Area ...
ugp01.c-ij.com/ij/webmanual/PrintStudioPro/W/1.3/EN/.../psp-406.html
figure: Settings area (Correction). (1) Black and White Tone Adjustment Area ... Move the slider to the right to darken and left to lighten the color. ... the XPS printer driver (Canon series XPS) for Printer in the Settings area (Print Settings).
Canon : PIXMA Manuals : MX920 series : Adjusting Intensity
ugp01.c-ij.com/ij/webmanual/PrinterDriver/W/.../Dg-c_intensity.html
You can dilute (brighten) or intensify (darken) the colors of the overall image data ...Used Settings, and then choosing Color/Intensity Manual Adjustment under ...
Canon : PIXMA Manuals : Image Settings
ugp01.c-ij.com/ij/webmanual/ScanGear/M/MFP/19.1/.../Sg-930.html
When Image Adjustment is set, the brightness of the specified portion of the ... Use this function to reduce show-through in duplex documents or lighten the base ...
Oct 20, 2015 | Canon PIXMA MG3222 Wireless Inkjet Photo...
Does the Canon Pixma collate?
Your higher end Canon MX printers can yes. Models like the Pixma MX750 and Pixma MX920 are good examples
Dec 03, 2013 | Canon PIXMA Office Equipment & Supplies
How to print address on envelope on canon mx892
Printing envelopes on Canon MX892: Remove paper from rear tray. Adjust gray width handlers to the size of your envelope. Insert a blank envelope in the rear feeder, with flap oriented on the back left side.
May 30, 2012 | Canon PIXMA MX310 All-In-One Printer
How do print on an envelope with the MP830
you should see a picture of an envelope in the paper tray area. remove any other paper and align the paper guides to the envelope. If you are using WORD make sure to change the paper type to the correct envelope size.
Jan 06, 2010 | Canon PIXMA MP830 All-In-One InkJet...
How topaper load cannon mp 160 pixma
Loading Paper into your Canon MP 160 Pixma.
A) Loading Paper :
Follow this procedure:
1) Open the Paper Support, then pull out the Paper Support Extension.
2) Place a stack of paper (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Set the Paper ThicknessLever to the correct position for the paper.
Note : Set the Lever to the left for most paper. When the Lever is set to the right, the confirmation message appears before the machine starts printing.
Important : Make sure the stack does not exceed the Load Limit Mark.
B) Loading Envelopes
Follow the following steps:
2) Prepare the envelopes for loading.
Important : * Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
* Remove any curling by holding the edges diagonally and bending them gently.
* If the edges of the envelopes are inflated or curled, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
* Ensure that no curl or puff exceeds 1/8 in. (3mm).
3) Place the stack of envelopes (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Load the envelopes in the Auto Sheet Feeder with the short side down.
* Set the Paper Thickness Lever to the right.
Important : Make sure that the stack does not exceed the Load Limit Mark.
Hope this helps. PLease rate my response.
Thanks
Have a good day.
Dec 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
How do you print envelopes on the Canon Pixma iP4600. What feeder do you put the envelope in? I need to print on square envelope 155mm x155mm and don't want the envelope to get creased.
I print envelopes a lot for my business.
What I do is I use the regular paper feed, and I open the flap on the envelope so that it's flatter. Simply slide the paper guide to adjust to the size of the envelope.
Also, typically the orientation for printing envelopes is sideways. You put the left edge of the envelope in the printer first. If you are unsure of the orientation, simply do your first print on plain paper. Then you'll know how to insert the envelope.
Oct 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Printing DL envelope on Canon Pixma iP4600
its not the problem of your way of operation, its the limitation of of the printer.
Jul 10, 2009 | Canon PIXMA MX310 All-In-One Printer
Cannot print envelope on MX310
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
    Note:
Printer Driver Settings:
1Select Envelope in Media Type.
  1. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
  2. * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Apr 02, 2009 | Canon PIXMA MX310 All-In-One Printer
How to print envelopes on my printer
Use The Recommended Print Area For the best printing results, adjust the top and bottom margins of your document to within the recommended printing area shown below. Click on the paper size listed for the recommended print area settings: A4 / B5 / A5 / 4 x 6 / 4 x 8 / 5 x 7 / Credit Card, Letter and Legal, Envelopes (DL / COM#10)
Caution: When printing is performed outside the recommended printing area, the top and bottom edges of the paper may curl, the print quality may deteriorate, or the printed side may be smudged.
The printer has both the recommended print area and the printable area, according to the paper size.
05sj00144_01.jpg Recommended print area: This indicates the recommended print area.
05sj00144_02.jpg Printable area: Although this indicates the printable area, degradation of print quality may occur.
Note:
  • Set Borderless Printing to print without margins.
  • In Duplex Printing, the printable area of the paper's header is approximately 2 mm narrower than usual.
05sj00084_03.jpg Letter / Legal
Envelopes ( DL / #10 )
Nov 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
207 people viewed this question
k24674
jasbo
jasbo
