Question about Toshiba Satellite 2455-S305 Notebook
Vertical lines are appearing on my toshiba laptop
Vertical lines are appearing on my toshib laptop screen. it has covered half the screen. they are in green,red, blueand pink colours
  • 46 Answers
First try to hook it into an external monitor if it looks good,I would have to say you have a damaged cable on your monitor.if you are comfortable taking it apart you can try to reseat the ribbon cable on the mobo.you can usually find an online manual for disassembly.
Posted on Apr 23, 2009
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
How difficult is it to replace a laptop monitor?
Hi There Joe,
I'm a professional Laptop repair specialist. Before you go any farther, either using your own or one beloging to friend, connect your Toshiba to an external monitor and see whether the lines appear there also, or the screen displays properly. This will tell worlds about your problem.
1. If the lines appear on the external monitor as well, it means that your video card on the motherboard is about to fail and you would want to go to eBay and type into their search box "Motherboard Repair". There are good companies there which I have used and you can get the problem repaired for around $100.
2. If the lines do NOT appear on the external monitor you could have one of several problems.
a. loose lcd cable connection on the motherboard or behind the lcd
b. failing Screen Inverter just below the lcd behind the frame
c. the lcd itself
If you intend to try any sort of repair on a Toshiba yourself, make sure a tutorial is available for your model at this site before you begin:
http://www.irisvista.com/tech/
Toshiba Laptops are generally a higher degree of dificulty than many others. Losing one wrong screw can cause the laptop to refuse to boot after reassembly because Toshibas use some screws to double as electrical grounds.
You'll have to be the judge of what you feel comfortable with, but I feel I've covered almost all possibilities except a spill on your laptop that you might not have known about.
Regards,
TheSelkie
Jul 14, 2010 | Toshiba Computers & Internet
I have vertical lines (15 of them now) on my Toshiba laptop.
I'm afraid when you see vertical line on an lcd panel, it most likely is screen failure. Ebay has plenty of screen from good companies in Texas. I get most of my screens from Ebay store LCDTECH99. They have the best prices, most screens are under 100 bucks and they ship right away. The Toshiba screen is an easy repair, Only the bezel needs to be removed in most cases. Below is a guide to show the process.
http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/take-apart-1.htm
Nov 27, 2009 | Toshiba Satellite P105-S6227 Notebook
My monitor started showing vertical lines, first a few then half the screen. Now, half the screen is black.
Your Laptop screen has either too much of Moisture in it or the display circuit at the laptop folding place is creating issue. Please take the machine to Toshiba Service Centre and they will do the needful. Any attempts to fix the problem by yourself will worsen the problem and respond quick.
Nov 16, 2009 | Toshiba Satellite P105-S9722 Notebook
Display has vertical white lines. Hook up a external flat screen and it works fine . Toshib Qosmio g25
this indicates you have a bad screen, and if you press around on the back (top) of the computer display the lines will disappear until you take your hands off the area effected, and the screen needs to be replaced.
Jul 12, 2009 | Toshiba Qosmio G25-AV513 Notebook
Vertical Lines on Screen
Either the cable has come loose, or the display is going out.
I would call Toshiba and see what warranty is left ...
Jun 23, 2009 | Toshiba Satellite P100 Notebook
Vertical lines appearing on my laptop screen
...not good. Generally means your screen is on it's way out.
Jun 22, 2009 | Compaq Presario M2000 Notebook
Thin Vertical lines on the screen
Ebay - new screens $110-$135. Google for step-by-step replacement instructions.
Dec 30, 2008 | Toshiba Satellite P30 P35 Series Notebook
Toshiba Satellite 2455-S305 Notebook Logo
330 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
