Question about Tefal T-fal Actifry - FZ7000002
Actifry spindle wont go round - Tefal T-fal Actifry - FZ7000002
My ActiFry Power Button is stuck and wont come back up or go down. So it wont turn on. Is it possible to fix it?
The button may be too large for the hole it fits in. If you can, remove the button and sand around the edges to make it a bit smaller.
Aug 03, 2017 | Tefal Actifry Family Ah900015 Low Fat...
I have a tefal family actifry and a green error flashed up and a long alarm. What is this telling me?
Tefal Actifry GH800215 user manuals GH800215
www.tefal.com/instructions.../Fryer/Actifry/Actifry.../1500634805
TefalThe Actifry Plus GH800015, GH800215 deep fryer allows you to make 1.2 kg of chips with only 1 ... To display Instructions & Manual, choose your language :.
Apr 13, 2013 | Tefal ActiFry Deep Fryer
I bought a new tefal actifry family Ah9000 and when open the box and connect it to power then pressed on/off button nothing happened. Just a green screen with hardly to see sun shape on the left side
Use the timer. Unlike the Actifry and Actifry Plus models, the timer on the Actifry Family controls the fryer, and turns it off at the end of the cooking time.
Jul 20, 2012 | Tefal ActiFry Deep Fryer
Paddle does not go round
Purchase a SS-992500 - The Transmission Shaft & Motor has defaulted. We have repaired many of these.
Depending on your engineering ability you may be able to do this yourself.
However, if you needa ny further help on the instruction for repair or purchase of part dont hesitate to contact us at:
www.wescoelec.co.uk
Sep 12, 2011 | Tefal ActiFry Deep Fryer
TEFAL Actifry element in back has blown is it replaceable
the same thing happened to mine i think it is a bad fault mine was nearly new good luck
May 14, 2010 | Tefal ActiFry Deep Fryer
Replacing the drum belt
Hi.
Ensure power is disconnevcted first!
  1. Locate the lid. On both left and right front of the lid you will find a cover. Remove covers and this will gain access to screws (probably will be star shaped heads so a normal philips screw driver wont work.) B&Q will sell them.
  2. slide top backwards. It might need a slight tap as its often tight. Push lid backwards and it should lift off.
  3. Now the drum spindle will be located at the back of the appliance. If the belt is still intact then you have a fault somewhere else. If belt has come off then you will need replacement belt, part number, 1603287
  4. Remove bottom plate, located at back of appliance. here you will see the motor spindle.
  5. This is now the tricky part. The belt is a stretch type so it will appear to be too short but the best way to do this is to put the belt around the motor spindle first. then place around one side of the drum spindle (normally black). If you have a extra pair of hands then as you stretch the belt over the spindle someone else can SLOWLY rotate the drum (by placing their hands inside the drum and holding on to the paddles) and you can then "thread" the belt round. You may need to do this a few times as sometimes the belt slips off.
Good luck.
AARDVARK REPAIRS
Nov 18, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
I have a qualcast 35s petrol lawnmower and i cant stop the blades going round when i start it it on tick over, it allways seem to be driven
Hi, first of all I would check that the cutting cylinder is correctly adjusted, i,e, just kissing the bottom blade.dont forget to re-adjust the chain. next i would remove the four engine mounting bolts and slide the engine away from the clutch drum so that you can check if the clutch shoes are binding on the spindles, if the spindles are rusty centrifugal force will throw the shoes outward to engage the drum but the springs wont be able pull the shoes back.try wd40 on the pins while trying GENTLY to revolve the shoe round the pin, hope this helps
Sep 12, 2009 | Garden
Tefal T-fal Actifry - FZ7000002 Logo
27 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Gerry Harvey
Gerry Harvey
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
