Question about Whirlpool RBS245PDS Electric Single Oven
Whirlpool Double Oven GBD307
The upper oven (which is also an electric convection oven) is heating on its own without being turned on. After trying to turn it off in the usual manner, it will stop for a short period of time. However, it will start up again on its own. The only way to stop it is to turn off the circuit breaker. The oven was purchased new about four years ago.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
There are three possible issues, one is a faulty ground. the computer uses ground to determine zero in binary logic. It could also be a stuck key on the input board, or the main control board. Check your owners manual, some units come with an exceptional warranty on the electronics. This is a big one and it may be worth your time to call a tech in to check it out. electronics are expensive and you can not send them back if you diagnosis is wrong.
Posted on Sep 25, 2007
SOURCE:
Whirlpool gbd307 why will The upper oven not work but the lower oven works
Have you checked the heating element supply voltage with a VOM? And have you checked for a popped/burned fuse to the bake element?
Aug 06, 2014 | Whirlpool GBD307PDS Electric Double Oven
Why my whirlpool GBD307 double oven top oven will not cut on, but the bottom one will. but after heating up, the oven starts blinking the start? button but it will not cut off, it shows a error code F
that's a bad touch panel or key panel,the number you sent isn't the full model number off of the oven so when you call to order the part you will need that.if you try to fix this yourself make sure the power is off.good luck
Nov 07, 2017 | Whirlpool GBD307PDS Electric Double Oven
My upper oven/ convection function on my dacor ecs230b will not heat
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
Sep 22, 2009 | Dacor ECS230 Epicure Electric Double Oven
Whirlpool Gold Series double oven electric model GBD307-PDQ309
Usually this is a touchpad and control panel fault but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
With the model number of the oven we could look up the code and be more specific about the problem.
Go here for: http://www.repairclinic.com/Whirlpool-Range-Stove-Oven-Parts
RepairClinic.com
asplogo.jpg?ver=23
appliance parts, help & more
Apr 09, 2009 | Whirlpool RBD305PD Electric Double Oven
How do I get into the fuse to change it on my whirlpool GBD307 PDQ7 oven? Where is it located?
There are different fuses, a fuse is located on control assembly board, a thermal fuse is accessible removing a panel at the back of the oven, or inside the oven.
Enter here to find assembly diagrams and parts for your model.
Contact the seller by phone if part is not listed on the website.
Jan 02, 2009 | Whirlpool GBD307PDS Electric Double Oven
Whirpool GBD307 - Display not working
We had the same error codes F2 E6. We were told to turn off the breaker to the oven for 5 minutes and then turn it back on and it will reset itself. We tried it and it worked! Whirpool wanted to send someone out on a service call. Thank goodness we didn't!
Mar 28, 2008 | Whirlpool RBS245PDS Electric Single Oven
Delonghi range oven
Bake- Normal convection- both upper and lower heating elements.
Conv. Bake- Semi-forced convection- both upper and lower elements, heat is then distributed throughout the oven via the fan.
Broil- radiation- The heat is radiated by the ifrared broil element.
Broil & Fan- Radiation and Ventilation- The radiated heat from the infra-red broiling element is distributed throughout the oven via the fan.
Mar 12, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Whirlpool RBS245PDS Electric Single Oven Logo
328 people viewed this question
Top Whirlpool Ovens Experts
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
