Question about Sharp AL 1631 Copier
Scanner bar will not move to scan the paper to be copied.
The scanner bar under the glass on our Sharp Al-1631 is 'hung up' and will not move to scan the copy. ANy ideas?
    Sniper:
  • 67 Answers
A piece of plastic locks your scanner in place, it is under the scanner up above where the copies come out. It turns 90 degrees.
Maybe some one turned and locked it.
Good luck
Bob
Posted on Apr 23, 2009
    President:
  • Sharp Master
  • 1,447 Answers
Yes your scaner lock is locked please unlock it
Posted on Jun 16, 2009
Its a Sharp AL-1631. It'll copy from the auto feed
Check under the scanner, there is a scanner lock that you may have hit removing copies. Its most likely in the locked position and stopping scan.
Jun 03, 2011 | Sharp AL 1631 Copier
The light flashes L and the a 1 repeatedly on my AL-1631copier and won't print the page.
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Sep 24, 2010 | Sharp AL 1631 Copier
Error code on display, L1 or 1L flashing. What is
Jul 15, 2010 | Sharp AL 1631 Copier
SHARP AL-1631, SCANNER NOT MOVING WHEN MAKING
You try any zoom copy, I maen 80% small then move scanner.
Apr 21, 2010 | Sharp AL 1631 Copier
The number count screen shows 3L and it won't make more copies. What does that mean?Chas Cantlon
Good Luck and thank you for using Fixya.
Mar 16, 2010 | Sharp AL 1631 Copier
Sharp AL-1631 scanner won't slide under glass plate
The Scanner home sensor maybe bad or dust mite be on it (it is what telle the copier where the scanner start position is. Or the motor for the scanner maybe bad or the scanner circuit board
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 26, 2010 | Sharp AL 1631 Copier
Sharp al-1631 error L1
Your copy lamp is faulty or scanner drive is not moving. Check the lamp and replace if not lighting.
If its the scanner, unlock the scanner lock above the paper exit tray.
Nov 25, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Aug 09, 2009 | Sharp AL 1631 Copier
Sharo al 1631 makes clicing noise and does not
Sounds like your scanner is jammed or the scanner motor has failed.
If you are so inclined, turn the power off, you can remove the glass and try to move the scanner by hand, if you can't move it then it is jammed, if you can move it to the middle and turn the machine back on, does it return it to its home position? if so, the motor may be OK, but the control board may have a problem, if not, the motor have likely failed.
Hope this is of some help.
Ed
Apr 30, 2009 | Sharp AL-1655CS Copier
Scan head lamp does not move
the scanner lock could be on. This is located above the paper exit
trat. It has a knob with a picture of a lock. It shoulb be in the lock position. The scanner bar could be dirty. This is located under the copier glass.
Dec 01, 2008 | Office Equipment & Supplies
Sharp AL 1631 Copier Logo
211 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
