Question about Dell Inspiron 1300 Notebook
Sd card reader problem with inspiron
I'm having dificulty with my del inspiron 1300, it seems very difficult to insert sd card into card reader slot and when in does not recognise it atall. how do i insert the card correctly?
many thanks
ella
Where do i stick my sd with adapter on my dell inspiron 1545
Most portable SD stick readers come with a USB connection so you just stick it into any spare USB port (see USB adaptor pic).
If you have an SD to SD adaptor that fits a small SD card into a larger SD card holder (see SD adaptor pic) then you also need one of the SD stick readers (above)
Sep 23, 2014 | Dell Inspiron 1545 Laptop
I have a Dell Inspiron One 2020 how do I view and SD card
This pc has an 8-1 card reader so you should be able to read your SD card unless it is bad. Does windows at least senses that something was inserted? if so you might need some software to read the card.
Sep 16, 2014 | Dell Computers & Internet
Memory card insertion computer sd
You will need an adapter. Probably a USB to SD Card reader.
The manual for the Computer is at the link listed.
http://www.dell.com/support/Manuals/us/en/19/Product/inspiron-1300x
Nov 23, 2013 | Dell Inspiron 1300 Notebook
My SD card reader on my Sony Vaio will not read the card...it seems to know its in the slot, but won't read any data and says 'insert the SD card' if I go to computer and try to read it. Any thoughts?
Take a can of air and blow some into the slot to make sure dust or dirt isn't getting the way of that reader trying to read the sd cards.
If you still get the same message try another SD card in that reader or try to see if another computer will read your SD card, if another computer will read the SD card and the slot still won't recognize the sd cards properly, then you know at that point the reader is bad. If the reader is bad, thats integrated into the motherboard so the motherboard would need to be replaced.
Nov 30, 2009 | Acer Aspire 5610-4648 Notebook
Does a dell inspiron 1300 have sd slot
No. This Delll is considered a "budget" laptop with no frills; however, it has a ExpressCard 34 slot that can accommodate a card reader.
Griffin is a popular brand that supports every flavor of SD.
Also, of course, a large number of USB card readers are available at your favorite electronics / office supply store.
Nov 06, 2009 | Dell Inspiron 1300 Notebook
My Hp SD card reader doesn't work how can I make it work again?
Did you insert the memory card properly? because if your memory card is not inserted properly, the SD card reader may seem not to work. And if probably the problem is from the SD card reader slot, then you have to give it to an engineer for repair or better still take your laptop to Hp customer service center for repair. Thanks
Sep 24, 2009 | HP Pavilion dv1000 Notebook
How can i use sd/mmc memory card reader on my laptop? ia am using dell inspiron 1525 model?
The SD/MMC memory slot is already configured to read standard and HDSD cards. Just remove the DELL blank from the slot by pushing it in until it clicks and release it. Then pull it out. Insert the SD/MMC card into the slot and push it in until it clicks. The DELL Blank is shorter than an actual SD/MMC card, so don't try to push the SD/MMC card any further than the 'click'. Remove by pushing in until it clicks, release, remove.
Jan 10, 2009 | Dell Inspiron 1525 Notebook
Have a dell Inspiron 1525 notebook with memory card reader, compatible with Memory Stick Pro - but i cannot figure out how to insert the memory stick into the memory card reader - an SD card slots in...
the MS pro may need an adapter if it's the mini kind. then that will plug into that slot. it still won't fit the same way as the SD card, so insert it carefully. there should be an indented area for the MSP card to insert.
Aug 18, 2008 | Computers & Internet
Putting my Sony 512mb PRO memorystick into my Dell inspiron 6400
The Sony Memorystick Pro is smaller than the standard SD card slot on your system.
Looks like you'll need an external reader
http://www0.dealtime.com/xPO-Sony-Sony-17-IN-1-CARD-READER-USB
Jun 09, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 1300 Notebook Logo
155 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
