Monitor not starting up -
Hello - i am having problems with the computer monitor. Last night everything worked fine but this morning when we turn on the computer the monitor starts up shows a message power saving mode then goes black. We have verified all cables and everything is properly secure.
Any ideas?
Kim
    New Friend:
  • 113 Answers
I think the Power Settings in your Computer needs to be changed. As whenever your computer been IDLE, it goes in a Power Saving Mode.
Adjust your Power Settings from the Control Panel "Power Options" and set them to "Balanced Power Settings" or as per your requirement. There are lot of options their to mention.
Hope your problem will be solved.
Posted on Apr 23, 2009
My monitor doesn't go on anymore. Las night I had a pop-up appearing on the screen. I closed my computer and started over again. I'm sure I didn't turn off my monitor. Everything went well until this...
First, check to make sure the power cable is plugged properly in the back of the monitor and into the surge protector. You can try a different power outlet, but if you're still having the same problem and the light isn't turning on, it's likely you've either blown the fuse inside the monitor, or you had a power surge and blown something inside the monitor. This happens when you don't use a surge protector and just plug the monitor into the wall.
That said, if the above doesn't work then you have a hardware problem with your monitor and it needs to be serviced.
Jan 11, 2011 | Computers & Internet
Monitor keeps saying no video input was fine last night and happened this morning
hello, please check your VGA cable,blue in colour with 15 pins.Make sure it was properly inserted. I believe that should solve the problem
Nov 18, 2010 | Philips 200W6 Monitor
My monitor was fine last night, when i woke up this morning it would not come on, the blue light is flashing, help
Press and hold the button, until the monitor turns itself off.
Then, turn it on, and hope that it works correctly.
Aug 21, 2010 | Proview PL926WBi 19" LCD Monitor
Car wont start battery is fine
Hi Dianna
I would look at the cables from the battery, possible that one of them has a break in causing the car not to start. I had that same type problem with my 02 Nissan and that was the solution.
Hope this helps
Matt
Sep 21, 2009 | 2003 Toyota Corolla
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
Viewsonic 19
Hi...there,
But of course...it's can. Asked him if the LCD Monitor got any power (a green light on) If it has, switch cables, if it have a DVI connection used that cable and see if it work. Still had a problems...Then the backlight is burnt out. Have a nice day!
Sep 07, 2008 | ViewSonic VX924 19" LCD Monitor
Computers & Internet Logo
331 people viewed this question
David Payne
David Payne
