Question about Linear Re-1 Residential Telephone Entry System Re1ss
We have a Linear RE1 telephone entry system. When we switched to U-verse, the gate opener system would not work with the telephone system. Now we cannot open the gate remotely.
Sliding gate wont always open
Since there are few details on the circumstances of when it won't open provided I will try to guess what is happening.
Usually this is related to the strength of the transmitter (clicker or remote) signal. If you have radio interference from ham radios, air fields or other government agency, it will affect the reception or your gate receiver. Other common issues include the distance from the operator, how long you hold down the button, and the age of the battery in the transmitter.
You might try extending the receiver antenna up higher. If this makes it worse, you may need a directional antenna like the Linear EXA 2000.
We have also found the Linear SMDRG narrow band receiver to work well when we have interference issues.
May 18, 2015 | L A Ornamental Security Electric Driveway...
I have a klik2 keyless keypad, i need to program it to a linear dalta 3 with 8 dip switches can you please help
The Klick is a universal keypad. That is misleading. It is only universal to the "approved systems" which there should be a list on the back of the packaging. I would suggest you read that list and you will probably notice that your model is not on it as KLIK does not make one that is compatible with dip switches. Good luck.
Feb 22, 2015 | Chamberlain Klik2u Universal Wireless...
Linear SWR-211 gate opened and got stuck when it tried to close. Tried reset and shut power off. Still stuck in half open position.
So the gate is stuck in a half open position? If you have already tried resetting it, you might just need to call in someone from the company. Some gates have an emergency retract option. You can look for that, at least it wouldn't be just half open.
Elisa Jed ' http://www.anviliron.net
Jul 09, 2014 | GTO Automatic / Electric Gate Lock Fm-143
Why is my mighty mule FM500 gate opener opening by itself?
Cathie,
Thank you for using GTO Products. If the gate opener appears to be opening by itself, then it's receiving an input from an accessory such as a transmitter, keypad, push button, exit wand, photo beam, loop detector, telephone entry system, etc.
By disconnecting these devices and reconnecting them back to the system one at a time, we can use a process of elimination to determine which device is causing the problem.
If you still need assistance, please call our tech support from the gate so we can help you troubleshoot. You can contact us at 800-543-1236 Monday - Friday from 8:00 AM to 6:50 PM EST
Technical Support
GTO Access Systems, LLC
Jun 29, 2014 | GTO Mighty Mule Automatic Gate Opener For...
Kepad does not respond
It sounds like it has already reset itself when you powered down for winter. These devices usually have a tiny lithium cell battery built inside the body, to maintain programme instructions in power down event. They don't last forever. Throwing a switch after any length of time can cause a short. Moisture inside can and does corrode unused electronics. Not very helpful but its very common. Red.
Apr 05, 2014 | Linear Corporation Linear AK-11 Keypad...
The Phone line is loaded when connected to the RE-1
try calling linear;s tech service support today and walk you through use a good 100 dollar multi-meter to check out going devices at dmarc and the device blessings friend!
Mar 10, 2014 | Linear Corporation Linear Access RE-1...
Is there a cluch in sliding gate motor
There is no internal clutch for the linear actuator gate motors... only a mechanical limit switch(micro-switch) which is only relevant in the arm-retracting motion, and a sight-wheel & eye which is used for electronic limits in the arm-extending motion.
Oct 16, 2010 | GTO Mighty Mule Automatic Gate Opener For...
Problem with KXTDA50 CO 4 Connected to Gate entry system
you can increase the timer that the system checks for dial tone... but you BEST bet would be to put the doorking into Intercom mode
May 26, 2009 | Panasonic KX-TDA50 Phone
Vehicle Entry Gate Will Not Open on Schedule.
after you program the door, you have to push "sel" and override the load until the next setpoint.
Apr 13, 2009 | Hardware & Accessories
Lucent partner system intergrated with AAS gate control and intercom
Sounds like the storm also took out the port in the phone system. try plugging in a standard telephone to the port and see if it works. if it doesn't them move the gate phone to a new port and try it.
Oct 13, 2008 | Lucent PARTNER18 Corded Phone
Linear Re-1 Residential Telephone Entry System Re1ss Logo
65 people viewed this question
Top Linear Home Security Experts
ka4iup
ka4iup
Albert Barkley
Albert Barkley
Are you a Linear Home Security Expert? Answer questions, earn points and help others
