Question about Canon PIXMA Office Equipment & Supplies
I have canon IR 3025 . I couldn't enter to service mode by *82*. Someone have done something so that I can't enter to it . What's the solution to this problem ? Plz rply to my objection . Thank you very much .
SOURCE: as to enter SERVICE MODE canon imagePROGRAF iPF700?thanks
Service Mode - With power off, hold paper feed (paper select) button and info button while powering on, release after initializing screen.
Posted on Jul 15, 2009
  • 22 Answers
SOURCE: Need default passcode
The above answer is correct but may need a little more explanation.
To get into Service Mode you hit the Additional Functions button, then hit 2 and 8 together then hit Additional Functions button again.
Once in Service Mode you can use the Copier, Function, Clear, Clr Pwd as described.
Keep in mind that once you have reset this password your unit is naked to the world on the network. If you have mailboxes and scanned documents stored on it they are accessible and anyone that has network access can now access the information and can set a password themselves...
Hope this helps.
Posted on Mar 16, 2010
  • 242 Answers
SOURCE: Canon IR 3180C. Error code E000008-0001.Enter mode
click this link to find the service mode procedure
and here is the service manual:
http://www.4shared.com/file/P_7SU82j/ir3100c-smpart1.html
http://www.4shared.com/file/6X_eK9Cx/ir3100c-smpart2.html
Posted on Nov 17, 2010
spinal
  • 287 Answers
SOURCE: I need to set a Canon IR 3025 so that the Scan
Hi fiona,
I am glad to help you.Press the "ADDITIONAL FUNCTIONS" button located to the right of the display. Select "communication settings". Now press "TX SETTINGS".Now press "common settings".Now press "Edit standard send settings". You will now see a screen that allows you to set the DPI value and file format.You will have drop down menus for each that allow you to change these settings. Once you have selected your preferred settings press the "OK" button located at the lower right. I have "FIXEDYA". :-) Rememeber, you can change these settings of a case per case basis on the main send srceen. Be well and smile when you get a chance.Please let "fixya" know I have helped. Thanx
Posted on Jan 24, 2011
SOURCE: How do one enter to Service Mode level 3 of Canon irc3200
That level 3 mode is only for Canon engineers. What counter are you looking to reset? The counters for most maintenance items are reset in service mode level 1. The total counter for the machine cannot be reset without replacing the main controller pcb & the counter pcb.
Posted on Jul 25, 2012
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
1. In standby mode, press the "Settings/Registration" key.
4. Press the "Settings / Registration" key.
5. The service mode screen is displayed.
Use the "Back" key to exit Service Mode
Jan 19, 2015 | Canon Office Equipment & Supplies
Paper jammed in canon ir 3025
adjustment in the right side on casset just turn the nobe
Jan 22, 2014 | Canon ImageRunner 3025 Black and White...
Scanning using canon image runner 3025N
Hi Swandi,
Have you installed the scanner utility software before?. If yes, you can use the software or uses other application such as photoshop :)
Have a nice day!
Printer Clinic
Jan 13, 2014 | Canon ImageRunner 3025 Black and White...
Please tell me how to find the main meter on the Canon imagerunner 3025
enter the service mode by pressing additional function 28 additional function check print there u can also print the same in system menu in misc p
Jun 06, 2011 | Canon Office Equipment & Supplies
I have replaced the toner cartridge in the canon image runner 3025 and it still says i need to replace the toner. I tried another toner cartridge but it still is not registering
try to do this, enter in service mode and in the copier menu find function and in this menu find install toner or TNRINST and hit the OK key.
Entering the service menu is easy:
press service key them 2 then 8 then service key then navigate the menu copier>function>install toner
Jun 05, 2011 | Office Equipment & Supplies
Canon ir 3025 service error
Pls. tell wich sevice error, eg. E019, E007,...
Jan 28, 2010 | Canon ImageRunner 3025 Black and White...
Need default passcode for canon iR 3025
Their is no default pass code, try to reset password thru service mode Additional functions, 28, additional functions, copier, function, clear ,clr pwd. That should clear all passwords.
Dec 23, 2009 | Canon imageRUNNER 4570 Copier
Service Mode
Press
82 Simulatneously
Oct 31, 2007 | Canon imageRUNNER 8500 Copier
old marine
old marine
