Ativa vortex hs1000 manual. Unit runs 100% of time and does not stop between sheets.
3 Suggested Answers
SOURCE: Ativa HS1000 (Vortex) - the
Disconnect from the electricity. Remove the bin. Flip the shredder upside down. Brush the blades to loosen/remove any cut paper. Then using a thin plier remove any jammed pieces of paper.
Posted on Oct 20, 2012
  • 34725 Answers
SOURCE: shredder Ativa Vortex HS1000. Will not stop running after shredding on -AUTO- setting.Is there a re-set or is something broken ?
There may be something blocking the detector that senses paper to be shredded.
Posted on Oct 31, 2016
Testimonial: "we had it apart.While apart We interrupted the sensor light and the machine started. removed the paper to allow the sensor to make contact. After 10 seconds (approx) the shredder stopped running. (both sensors). Reassembled unit and inserted paper. shredding completed and it failed to turn off. (all for naught !)"
My Ativa HS1000 shredder has a bad switch. I must press on the basket for the shredder to start. It will run forwards or backwards without any paper in. Can the switch be repaired or replaced?
Unless this is a very high end office machine the answer is no they are no repaired in most cases just replaced. For a definitive answer contact a retailer of the product to see if the switch is available.
Mar 17, 2017 | The Office Equipment & Supplies
My ativa 12 x-cut paper shredder runs for 1/2 sheet then stops. how would you identify problem and fix it
The sheet detector may be malfunctioning. Your shredder may have to be cleaned to restore proper operation. Mine gets clogged periodically and has to have the bin removed so the entire shredder can be turned upside down to perform dental hygiene on the teeth. Paper shreds even get jammed in the spaces between the teeth. Flossing doesn't help!
Mar 07, 2015 | Shredder Office Equipment & Supplies
Auto off does not work how do I fix this?
Check to see if the feed is clogged up. If it is, clean it out and try to shred. These machines don't last forever, it may be worn out and time to buy a new one.
Sep 14, 2014 | Ativa MDM6000 6-Sheet Micro-Cut Shredder
I placed less than 12 sheets of paper in the ativa 1250 shredder. it's reading overload. can you help?
The problem seems to be the plastic gears and/or bearing supports. Unless it is in warranty, it's going to cost you more to repair than replace, and even then Ativa's customer service is not the best and neither are their shredders: I suggest you look at http://www.complaintsboard.com/complaints/ativa-paper-shredder-c31646.html?page=2
Jun 29, 2014 | Office Depot Ativa DQ60M Shredder
No power to shredder, no reset button, reverse will not solve
The motor may have overheated and failed, especially if the shredder was operated at its rated capacity or operated continuously for long periods of time. The specs for these devices tend to be exaggerated.
Apr 22, 2014 | Ativa Hd1600 16-sheet Cross-cut Shredder
Ativa HS1000 (Vortex) - the red light indicating that the shredder tray is full is on, however it's empty. There is clearly a piece of paper stuck in the shredder, but it's not letting me reverse...
Sep 05, 2011 | Office Equipment & Supplies
Red light is on. Ativa Vortex HS1000, looks like a thermometer will not do anything at all. what is going on?
That thermometer light is only on when the unit is overheating. If it is not doing anything, that is a good thing!
Jul 23, 2011 | Office Equipment & Supplies
I have an Ativa MD 460c paper shredder that reads misalignment. What do I do?
I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had overheated. The temperature light did not come on. I wait for over 30 minutes and tried using it again. I was able to shred a couple of sheets of paper and it stopped again. The next morning I couldn't get it to work at all. The green ready light is on but the shredder will not start. I can't tell if anything is stuck in it. How do I getting running?
Sep 08, 2010 | Fellowes DM8C Cross-Cut Shredder
I lost my manual to my Ativa phone system and need to set up my answering system. Model # AD 583 S/N EH 100 108 897
This model number (AD 583) is now discontinued (see this link) and the manual is not available for download.
You will have to contact the manufacturer's customer support department on 1877-777-4357 (Monday through Friday
8AM to 8PM Eastern Standard Time
) to get a copy of the manual.
Thanks for using FixYa
Aug 10, 2010 | Office Depot Ativa D5772 Phone
176 people viewed this question
jasbo
jasbo
