Maximum ram supported by 845 glx motherboard
What is the limit of ram supported by 845 glx motherboard
  • 61 Answers
Hello
Can't find any motherboard with that name.
Intel 845GL chipset supports max 2GB of memory.
If you are running windows, you can check more details with
a program called SIW.
It's free and downloadable from http://www.gtopala.com/siw-download.html
Download and run it. It will show you for example the maximum amount of memory your motherboard can handle.
Best regards,
Zizzler
Posted on Apr 23, 2009
I have motherboard Mercury PVM7P, i installed 2 GB DDR2 RAM 800 MHS but its showing only 448 MB what is the solution for that anybody can solve it, how much maximum RAM can support this motherboard
Hello you can find info here:
http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=677
The mainboard supports:
2 x 240-pin DDR2 DIMM socket support up to 2 GB DDR2 533
Maximum: 2GB
533 mhz is probably limited speed by the CPU and the FSB settings.
So you have to try with another type of ram module, the 533 module, because 800 mhz is probably to fast for this mainboard.
Good luck
Aug 22, 2013 | Mercury Computers & Internet
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
Mar 20, 2012 | ASUS Intel 845 Chipset P4B-FX Motherboard
Ram support for intel 845 motherboard
Hello. this website will show you the supported RAM for your Motherboard.
RAM Support
Hope this helps!
Apr 11, 2011 | Intel D845EPI (INTELKD845EPILPAK10)...
My mother board of asus p5rd2-vm is not detecting more than 2gbram memmory.any solution please.
The Motherboard supports a maximum of 2GB RAM. It is a hardware limitation.
2 x Dimm, Max. 2 GB
Apr 07, 2011 | ASUS P5RD2-VM Motherboard
What is competible RAM for GV 845
''The Desktop Board D845GVSR has two DIMM sockets and supports the following memory features:
  • 2.5 V (only) 184-pin DDR SDRAM DIMMs with gold-plated contacts
  • Unbuffered single-sided or double-sided DIMMs
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • DDR333/266/200 MHz SDRAM DIMMs only
  • Serial Presence Detect (SPD)
  • Suspend to RAM
Feb 01, 2010 | Intel D845GVSR Motherboard
How much ram can be supported for 845 p4 motherborad
My Intel 845 WD motherboard after upgrading the BIOS was able to support 4 Gigs of RAM.
Jul 08, 2009 | IBM (02R4087) Motherboard
Which ram sported by 845 intel motherboard
Check page 7 at this link for memory module requirements for 850MD and 850MV. http://download.intel.com/support/motherboards/desktop/d850mv/qrg.pdf
Jul 07, 2009 | Intel Motherboard
Ram support
Any 845 intel board should support 512 ram.may be the one u have brought is defective.plz be specific and more detailed quires when u post next time.
May 10, 2008 | Intel Motherboard
Ok. So you've defined the Intel 845 chipset on your motherboard.
But is it the 845 or 845G chipset?
Click HERE for the specifications of the Intel 845 chipset.
Click HERE for the specifications of the Intel 845G chipset.
Peepnklown is only HALF right.
The Intel 845 chipset does NOT support PC133 memory.
The Intel 845G chipset DOES support both DDR and PC133 memory.
The difference?
The 845 has a single memory controller for DDR memory.
The 845G has two memory controllers. One for DDR and one for PC133.
Although you're going to need DDR memory as it is FASTER and less expensive than the older PC133 memory. (Believe it or not.)
I do NOT recommend using Corsair's ValuSelect memory on this chipset. I have two boards with the 845G chipset and that type of memory does not allow the board to boot.
These boards typically come with DDR266 (PC2100) modules installed.
I would go ahead and buy DDR333 (PC2700) memory for it. The board you have may not utilize the full speed of that memory, but will use tighter memory timings if the RAM is clocked down by the board. This will result in better efficiency of memory use by the processor.
Think of it as giving the motherboard "breathing room".
I could recommend PNY memory for the most basic compatability. (Not that they manufacture their own RAM modules...) Or perhaps Nanya, Infineon or Microtek.
Look for memory compatability lists for your particular motherboard module online. You could also use PNY's memory configurator on their website.
Click HERE for PNY's memory configurator.
Good luck.
Cyryl
Nov 10, 2007 | Intel Motherboard
Computers & Internet Logo
326 people viewed this question
David Payne
David Payne
