Question about Savin Copier Supplies; Toner for 3515, 3515F, 3515MF, Black
My Savin 3515MF doesn't believe I replaced the toner. I have replaced it a few times, so I followed the same instructions as before but to no luck. HELP!! Please and thank you!
    New Friend:
  • 38 Answers
Try cleaning any excess toner from the sensors and any glass inside the same panel as the toner bottle hopper.(the glass slides in and out). Use compressed air around the area where the toner pours into the developer but be careful not to blow out the developer.
Posted on Oct 11, 2013
4 Suggested Answers
spinal
  • 287 Answers
SOURCE: Savin 3515MF, copier and printer features are
Hello. Most likely there is some sort of debris in the optics.You can verify this by pressing the "USER TOOLS" button (usually located toward the top left of the operator control panel, although I dont usually deal with the 3515) and select "counter".Then select print counter.This will generate a copy of the meter reading of the device and this print will come directly from the engine of the device and will eliminate everything that has to do with the optics. If this print looks good(no lines) then you know that the scan glass and/or the mirrors are dirty.If this is the case then you need to turn of the copier.Now, lift the document feeder completely up so it rests in the up position. You of course will see the LARGE platen glass in front of you which you might place a document on in the event that you need to copy something that you cant run thru the automatic document feeder.BUT, look to the left of the large glass and you will see a SMALL strip of glass that is about 1 inch wide and as long as the large glass.This narrow strip of glass will cause lines on any document scanned thru the document feeder if it is dirty.The dirt may exist on top(where you can easily reach it but perhaps have to strain to actually see,or on the backside which will require the removal of the left index plate and the top edge plate (5 screws) and then the removal of the large platen glass.This will give you access to all the optics.Make sure the power is off before you jump in.Once these items are removed clean the back side of the small glass(at this point you can actually remove it for ease of access using a soft slightly damp cloth.Since you are this far,you shouls also clean the mirrors, the illumination lamp and its reflectors with a soft cloth.You may reach down and manually pull the scanner assembly to the right as it normally would move (as if it were making a copy) in order to gain better access to everything, once again using a soft cloth.There is now need to worry about the position of the scanner assembly when you are finished since when you power up the device it will seek and find its "home" position by itself.I bet you will have just solved your problem. Take care :-)
Posted on Jul 11, 2010
SOURCE: Please, may i use savin toner powder type 6075 in my savin 2070dp bottle???
ABSOLUTELY NOT!
Posted on Mar 24, 2012
  • 3 Answers
SOURCE: toner light and message won't go out
try to check the toner bottle holder.there are some patrs inside likethe bottle chuck,seals ,foam
Posted on May 23, 2012
I replaced the tone cartridge in my Savin 2400WD copier, but the light still indicates that I need to change the toner cartridge. What do I do?
I hate to say it but switching it off at the wall waiting a minute and then back on sometimes resets its little brain.
I trust the toner cartridge is all correct for this model.
May 13, 2015 | Savin Office Equipment & Supplies
Trying to replace toner in a savin 9922dp. install the toner cartridge, copier runs like it is loading the toner but then the error message to replace toner appears again (over and over)
take the toner out - whilst the green handle is up (this will get your hands dirty) feel inside for a left over cap from a previous toner. remove it and put your new toner in. this should sort it
Oct 02, 2013 | Savin 9922DP Toner 6 Ctgs/Ctn 66000 Yield...
Toner light and message won't go out
Hello sir; You have to replace toner senser, it located at the bottom of developer unit. have any problem please contact us, good luck!
Jul 15, 2010 | Savin Office Equipment & Supplies
Savin 3510 add toner ,new toner in machine
THIS PROBLEM ALSO OCCUR IN RICOH AND GESTETNER/LANIER AS THEY SHARE SIMILAR OPERATING SYSTEM. WHAT YOU CAN DO IS TO CHECK THE TONE HOPPER OUTLET ,SOMETIMES IT IS BLOCKED BY MYLAR COVER WHEN YOU REPLACED THE NEW TONER..YOU JUST TURN THE TONER BOTTLE/TWIST A BIT AND YOU CAN SEE THE TONER WILL COME OUT FROM THE HOPPER OUTLET. IF NOT TRY TO FIX THE MYLAR COVER.
THE SECOND PROBLEM IS BLOCKED TONER INLET IN PCU .YOU HAVE TO TAKE OUT THE PCU & CHECKED THE TONER INLET,SOMETIMES IT IS BLOCKED BY SEAL OR THE JAMMED INLET CLOSURE MECHANISM AND IT CAN BE REPAIRED IF YOU HAD THE EXPERIENCESD SERVICING THE PCU. GOOG LUCK
Mar 15, 2010 | Savin Office Equipment & Supplies
Can I scan directly to my computer without having to scan via email with a Savin 3515MF machine?
If you are using XP, click on start, then go into control panel, then to scanners and cameras.
From there select your scanner and follow the directions for scanning.
With vista, click on the start button, then type in scan. There should be an option to "scan a document or picture"
Apr 07, 2009 | Office Equipment & Supplies
How to change and program fax numbers into Savin 3515MF copier
"user tools"
"system Settings"
"key operator tools"
"address book Management"
"Program/ Change" or "Delete"
.......and proceed to make the changes as you wish
All of the manuals can be downloaded here, but they can be difficult to follow.
http://www.ricoh-usa.com/downloads/manuals/bw/aficio1515/
Mar 02, 2009 | Office Equipment & Supplies
SAVIN 3515MF
open the right door. Open the front cover. Remove the toner assembly, not just cartridge. Unplug wire, pull out.
Mar 12, 2008 | Office Equipment & Supplies
Ricoh 1018d won't add toner after installing toner bottle.
the part numbers are different for each toner from ricoh, Lanier, Savin and Gestetner. From what I recall is the bottles are different, check the old bottle vs new. Also if the machine had run very low you may have to open and close the fron cover several times, this intiates a toner feed program.
www.p4photel.com
http://www.websitetoolbox.com/tool/mb/copierquestions
Feb 26, 2008 | Ricoh Aficio 1018D All-In-One Laser...
Savin Copier Supplies; Toner for 3515, 3515F, 3515MF, Black Logo
153 people viewed this question
Top Savin Office Equipment & Supplies Experts
CheckitRight
CheckitRight
George Mclaughlin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
