Question about Sennheiser HSL 10 Handset Lifter
Headset lifter won't lift. When unplugged and re plugged light flashes blue then purple then flashes red.
Red light flashing
The lifter is a piece of junk. The red light means its time to get another. If the lifter will not lift the handset then it's time to get another - the best thing is do not get one to start!
Nov 11, 2013 | Sennheiser HSL10 Headset Lifter - BW900...
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Headlight blue light is flashing and won't do anything else
If you hold down the power button (and keep holding!) while wearing the headphones, you will hear three beeps (keep holding! If you lift your finger, you have wait a moment to start over) followed after a moment by two beeps. If you do this while the headset is NOT on, it will enter the "discoverable" mode and the lights should flash red/blue red/blue. If you do this while the headset is on, the second set of beeps sounds a little different, and those tones mean the headset is turning off.
The "manual" (a single sheet of paper) for this device is a joke, and website technical support is nonexistent.
When I first purchased mine, despite the poor instructions, I was satisfied, due to the low price. But I've only had the device for less than a month, and I've only used it three times, and suddenly I can't get it to pair with my laptop or my phone, though it had worked find a couple of weeks ago, last time I used it.
Sometimes you get what you pay for, I guess. Disappointing.
Dec 08, 2012 | Inland ProHT Bluetooth Headset Red
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Manual
use this site and put 220 in the search box - your explorer 220 is found and you can download the user guide http://www.plantronics.com/north_america/en_US/support/manuals.jsp;jsessionid=83D442E12D37E83038D66C83670075A9.delta#results
see page 14 for details of the lights
  • Powering on Blue flashes
  • Powering off Red appears and goes off.
  • Charging battery Red solid light.
  • Low battery Red flashes.
  • Pairing mode Blue/red flashes.
  • Missed call Purple flashes. Single press the call control button to cancel.
  • Ringing Purple flashes. Briefly press call control button to answer the call.
  • Press call control button for 2 seconds to reject the call.
Apr 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
H700 Motorola Bluetooth Headset
Make sure that any devices previously paired
with the headset are turned off. If the indicator
light is flashing in blue, turn off the other device,
then close and reopen the headset boom. The
indicator light becomes steadily lit in purple
indicating the headset is now in pairing mode.
Jan 03, 2010 | Motorola Mobility H700 Wireless Headset
Plantronics CS55 requires lifting handset on phone
Please note that your hand receiver has to be off the hook when using the headset.
This is correct, additionally you can use a handset lifter accessory, such as the HL1 or HL10.
Subscribing Headset to Base:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
May 28, 2009 | Plantronics CS55 Wireless Headset
Quick Red Flashing Light on Lifter
I think I just fixed the same problem on mine...
My phone has a headset button. It took a couple tries - but 2nd attempt it worked & I see no more flashing red.
I pushed my speakerphone button on the phone, then hit the lifter button on my headset...then hit the sensor button...and voila!
Jan 13, 2009 | GN Netcom Remote Handset Lifter GN-1000RHL...
Plantronics CS55/HL10 Wireless Office Headset System with Lifter won't lift headset
You may need to re-subscribe the headset.
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
To Re-Subscribe:
Jan 12, 2009 | Plantronics CS55/HL10 Wireless Office...
Sennheiser HSL 10 Handset Lifter Logo
362 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
