Question about 2000 Pontiac Grand Prix Intake Manifold Upper V6 3.8L excluding Su
How to replace intake manifold on a 2000 Pontiac Grand Prix
  • 1,013 Answers
Here is a great video that should help you with getting the manifold off and on:
http://www.youtube.com/watch?v=YZjEKSqR5Qg
Posted on Oct 11, 2013
How to remove intake manifold for 1997 pontiac grand prix
You have to remove anything that is connected and in the way of the intake. Remove the fuel rail, the EGR valve and supply pipe from the manifold, the map sensor, the vacuum for the fuel pressure regulator, the alternator and support bracket, the water pipes for the throttle body, and the bolts that hold it down.
Jun 09, 2015 | 1997 Pontiac Grand Prix
What are the intake manifold torque specs on a 2005 Pontiac grand Prix gtp 3.4 liter with super charger?
If it were mine, I'd want to be very sure what it was and so I always use a Repair Manual I can see and read, but that me.
Mar 13, 2015 | 2005 Pontiac Grand Prix GTP
3100 engine overheating
all GM cars and trucks have a problem with bad intake manifold gaskets. it is a big problems. this is a picture of a 2004 pont. grand prix with low miles at my garage
Dec 27, 2012 | 2000 Pontiac Grand Prix
There is a vacuum line that goes from the bottom of the map sensor on a 1997 potiac grand prix. What does it go to.
The vacuum line goes from the Manifold Absolute Pressure sensor directly to the Intake Manifold.
Somewhere on the intake manifold there should be a place to connect it.
Jun 22, 2011 | 1997 Pontiac Grand Prix
Pontiac grand prix gt 3800 dexcool leak
Do you see the coolant leaking on the motor? From the drivers side, you can inspect the intake manifold...unfortunately as good as this motor usually is...it is known for leaking at the intake manifold...and requires a new intake gasket...DO NOT USE dexcool after the replacement...many teams believe the dexcool is part of the problem...use the coolant that "For All Coolant Systems" is still the green anti-freeze...Hope this helps.
Feb 28, 2011 | 2003 Pontiac Grand Prix
I have a 2000 pontiac grand prix gtp with supercharger. I have oil in coolant reservoir, I am not getting the white steam from exhaust pipes. car runs fine. not overheating. I checked the oil dipstick and...
The reason for this is because your trans cooler(which is built into the radiator itself) has failed and burst causing trans fluid to contaminate the cooling system.The fix for this is to remove and replace the radiator with a new one and then flush your cooling system to remove all trans fluid.I hope I could help!!! Any other questions please get back to me and rate me accordingly.
Apr 10, 2010 | 2000 Pontiac Grand Prix
Need to know where the knock sensor is in a 2000 grand prix
Under the intake manifold in the valley between the cylinder banks.
Oct 01, 2009 | 2000 Pontiac Grand Prix
98 Pontiac Grand Prix Overheating
YOU NEED TO REPLACE THE UPPER INTAKE MANIFOLD. ALSO, YOU WILL NEED TO REPLACE THE LOWER INTAKE MANIFOLD GASKETS. THIS IS A MANUFACTURING FLAW. THE PLASTIC INTAKE CRACKS CAUSING AN INTERNAL COOLANT LEAK. YOU CAN RESEARCH THIS ON LINE.
Apr 22, 2009 | 1998 Pontiac Grand Prix
2000 pontiac grand prix se ecm location
located in air box beather box for intake.
Jan 11, 2009 | 2000 Pontiac Grand Prix
2000 Pontiac Grand Prix Intake Manifold Upper V6 3.8L excluding Su Logo
144 people viewed this question
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Tom
Mike Stager
Mike Stager
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
