Question about Garmin Nuvi 660 GPS Receiver
Bluetooth will not enable
My bluetooth on 660 is disabled and will not enable when try to change it. the screen shows "enabling Bluetooth" for ever or untill i switch 660 off.
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    You need to connect your Nuvi to your PC via a USB cable, download Garmin's webupdater and reflash the system O/S & bluetooth on your 660. The latest version is v3.4. If you don't know how to do this, I can help you with it. I've done it hundreds of times.
    - Jim
    SHARCNET-USA
This is solved in a related post by silentspoon
http://www.fixya.com/support/t236067-bluetooth_enable
I just tried it for the same problem, worked great
Posted on Apr 23, 2009
Hi i have a u135 and it hasbuilt in blue tooth but i donot know how to activate could u help
Not sure if this will work for your model but its worth a try. Copied from MSI support faq website
You have to press the WLAN button located right next to the power button in order to enable/disable the Bluetooth function. Press WLAN button once, Enable WLAN. Press WLAN button twice, Enable Bluetooth. Press WLAN button thrice, Enable both WLAN and Bluetooth. Press WLAN button four times, Disable both WLAN and Bluetooth.
Aug 26, 2010 | MSI U100-422CA Notebook
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
The bluetooth turns on using FN + F11 it should turn the wireless too but doesn't MSI U100
As per the manual the FN and F11 keys turn on both Bluetooth and Wireless so you need to try it will turn bluetooth and then it will turn on wireless, you can check them by LEDS
Press and hold the Fn button, and then press the F11 button
repeatedly to enable or disable the Wireless LAN or Bluetooth function
recurrently.
Wireless LAN and Bluetooth:
�� Wireless LAN LED indicator glows green when Wireless LAN function is
enabled.
�� Bluetooth LED indicator glows blue when Bluetooth function is enabled.
�� Both LED indicators glow green and blue at the same time when both
functions are enabled.
�� Both LED indicators go out when both functions are disabled.
�� Note: For flight safety consideration, make sure these two LED indicators
go out when you are in flight.
Let me know if you are able to turn the wireless on
Also i will suggest you check in device manager that you wireless adapter is enabled
Regards
Dec 02, 2009 | MSI U100-001US Netbook
Ecap not working after updating bios
On my Eee PC updating the BIOS can turn off the Ecap, webcam, WLAN, and Bluetooth.
(Ecap gives the message "driver not found".)
The systems tray contains an applet for changing the screen resolution and enabling/disabling the webcam, WLAN, and Bluetooth.
By disabling, then re-enabling, the webcam life returns to Ecap.
Apr 17, 2009 | Computers & Internet
How do I start bluetooth on the qosmio g25-av13?
Try the ff:
1. Are you also using a wireless internet? If you are and you cannot also connect on wireless, make sure that the wireless is enabled on your laptop. On the left side of the laptop there is a on/off switch push the switch to on. (beside the usb port).
2. if it is already on, make sure that the bluetooth is enabled also, you can check it on control panel, system, hardware, device manager, bluetooth, right click on bluetooth driver, if you see enable bluetooth click on it, if you see"disable bluetooth" that means it is already enabled.
3. If the above is already configured, lastly, look for the bluetooth icon (bluetooth manager) on the lower part of the screen on the taskbar/tray if you see the bluetooth icon, right-click on it then click "Enable Bluetooth Radio". Now, if there is no bluetooth icon on the tray at the lower right of the screen, go to Start, Toshiba, Bluetooth, Bluetooth Settings, inside the Bluetooth SEttings, click on Bluetooth, Options, CLick on Enable Bluetooth Power, also, inside the Tray Icon (still inside Bluetooth Settings) select an icon so you can always see the status of your bluetooth on the Tray and you don;t need to do and check everything everytime you cannot connect via Bluetooth.
Hope this helps.
Tricia
Aug 19, 2008 | Toshiba Qosmio G25-AV513 Notebook
Garmin 760 is stuck on enabling bluetooth
Seems they have been having the identical problem with the 660
Here's a link to the solutions..
http://www.fixya.com/support/t179960-garmin_nuvi_660_bluetooth
The 2 best suggested fixes were probably that you need to reset the garmin ( instructions at link)
Or update the bluetooth software ( Probably the best solution)
Sad that the left hand does not know what the right hand is doing but this is what happens when you have a marketing company in one country having their product made in another... :(
Aug 17, 2008 | Garmin Nuvi 660 GPS Receiver
Enabling Bluetooth locked up
I had the exact same problem, very similar scenario. I seem to have fixed it by...
1. entering maintenance mode (press finger on upper left corner of screen during power up)
2. Press 'View Diagnostics'
3. Page to (Press 'Next' 5 times) Bluetooth Status Page
4. Press 'Updt PR'
5. Wait for 100% progress bar
6. Exit by pressing 'quit', then 'restart'
Good Luck
Feb 06, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin 660 gps Bluetooth problem
Note: This is for a 550c Street pilot
1) Turn on unit
2) Press VIEW MAP
3) Press SPEED in lower left hand side of map
4) This will bring you to the Trip meter screen on this screen press the round speedometer at the top of the screen for about 10 seconds this will bring you to the SYSTEM BIOS.
5) From this point forward be careful you can mess up your unit by changing the wrong thing.
6) Press NEXT until you come to the BLUETOOTH STATUS screen.
7) Now press UPDT P this should complete your update.
Nov 13, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 - Bluetooth
I fix this problem for my Nuvi 660 Europe. I found resources in Italian language only: 1 - go to http://www.garmin.it 2 - in the search texbotx (i the up left corner of the page) type bluetooth and press enter 3 - click on the 1st faq that will appear 4 - download the file FileBluetooth.zip 5 - unzip the file 6 - copy 006B055301.GCD in X:\Garmin\RemoteSW directory 7 - reboot your nuvi At this poin bluettoth would be ok newly. Bye
Aug 08, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
239 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
