Question about Whirlpool LSR5132PQ Top Load Washer
Washer problem it is a crosley ,it makes squeaky noises ,water runs at the bottom of washer.
  • 94 Answers
If it makes a squeaky sound the belt could be loose or worn or wearing out. It it leaks out the bottom it could be a worn out or loose hose, or a leaky seal. The hose is easy. The seal is difficult.
Posted on Sep 25, 2007
It's making squeaky noises and the area where the long bolt where the handles are seem to have loose washers how do it get it loose to put on new washers because it won't unscrew.
Try soaking them with WD 40 and spray where the squeaky noise is coming from with it ,might be just be dry and in need of lube.
Oct 03, 2015 | Area Exercise & Fitness
Crosley 5000 front load washer won't spin
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with either the pump, door lock assembly or timer. Contact a professional to move forward accurately.
Nov 24, 2012 | Crosley Washing Machines
Our Crosley washing machine (Model # CW5000W) will not spin all the water out of the clothes and is making a bad noise while it spins.
Three possibilities here,
One, you've overloaded the washer with clothes, throwing the washer basket on tilt because of the extra weight and force against the agitator. Remove the wet clothes from the washer and try continuing the cycle.
Two, One of the elastic/spring arms that centers the basket inside the washer housing has broken and is allowing the basket to simply flop around. Disassemble the washer and inspect the basket supports.
Three, The center post that the washer basket sits on is going bad - The most common reason is that the bearings have gone bad. Disassemble the washer and replace the bearings at the base of the basket where it connects to the motor.
May 04, 2011 | Crosley Washing Machines
I have a brand new Maytag Bravos MCT top loaded washer. It makes a squeaky noise when agitator is cleaning. The squeak is getting louder and I've probably only used the washer a dozen times. We checked...
I had this one come up on a washer I had professionally installed for a client. When I looked into it I found there were shipping blocks made of squeaky Styrofoam the installers left in place. Only made the noise when it was full of water and working hard shifting back and forth in agitation. It said right in installation instructions to take the shipping blocks out too.
Feb 20, 2011 | Maytag Dependable Clean Top MAV5920EWW Top...
My front loader washing machine is making a kind of squeaky noise when it spins. The washer is working..but wondering what it could be.
If the noise comes from the drum rather than the back of the machine it could be the drum bearings on their way out.
With the drum empty take hold of the top and bottom of the drum edge (from inside the drum). Gently try to lift and lower the drum, you may hear a slight knock - that's the bearings failing. Water enventually gets past the seal on the bearing and degergent in the water dissolves the grease in the bearing, causing it to fail.
Sep 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Tub is filled with water but will not do anything but make noise
lid switch is defective and or the lid is loose, tighten the lid screws left and right side of lid. nbcrca:)
Apr 11, 2009 | Crosley CAWS729MQ 3.2 cu. ft. Washer
Loud squeaky Noise
this is not 100% diagnosis as can't listen to noise but fault may be bearing lip seal disintegrating which is a serious fault and if im right then bearing will shortly go as well. reason it is noisy during start is that seal is dry and gets wet when full of water
Apr 18, 2007 | LG WM-2277HW Front Load Washer
Spin Cycle/Machine makes noise and moves
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
Jan 15, 2007 | Crosley CAWC529JQ Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
136 people viewed this question
Dan Webster
Dan Webster
Sal De
