Question about Royal wes50 surround sound wireless headphones
Ho do I hook these up to my tv - Royal wes50 surround sound wireless headphones
HOOKING UP THESCOSCHE 500K MICRO FARAD CAPACITOR. I LOST THE HOOK UP DIAGRAM AND DON'T WANT TO HOOK IT UP WRONG
Connect ground wire to ground. Connect positive wire to the same positive wire as the amp is. If you lost the charging resistor then connect the wire to the cap first then connect to the power source. This will keep it from sparking and damaging the plating on the connector.
Jul 31, 2016 | Heating & Cooling
I can't find the picture of my play station 3 on this tv. I can't figure out ho to change the tv mode input. I can't find the picture on the tv
If you had this on an HDMI input before you will have to do a reset. Press the power button for 5 to 6 seconds till it beeps. You should be able to select your video output type after that. Don't worry this will not effect anything but your audio and video settings.
Feb 05, 2013 | Televison & Video
I have VGA to an HDMI cable when i hooked it ho tv it still show black screen no signal
Hi.
You will need to tell the laptop to switch displays from the laptop to the TV screen, this is usually done by holding down the FN key and pressing one of the F keys. With HP laptops this key is usually the F4 key.
Regards.
Jan 29, 2013 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
Sound but no picture on my wii
Check the audio cables and make sure you have them all hooked up correctly and if that doesnt help ho ok up another device and see if it does the same thing and if it works then your cable hook ups on your wii are bad
Dec 18, 2012 | Nintendo Wii Console
Tv mai only audio aa rahi hai vidio ati hai aur chali jati hai tv mai kya kharab ho gaya hai
dear Mishra g,
ap k tv me loosing he kindly isko check krwai .sirf solding se thek ho jai ga.
Regards
Salman
Pakistan
Feb 10, 2011 | Televison & Video
Sir, hamari tv ka name thomson hai hamari tv
there is problem with your power supply.Must be fuse,capacitor,Str or FET are short or open.But care fully there is live voltages if you know that how to replaced then ok.
Oct 18, 2010 | Thomson LCDB 03B 27 in. Television
Ho do the fule lines hook up to the carbrator
How do the fuel lines hook up to the carburetor, huh? Well...it's not too complicated. Small diameter line coming out of fuel tank goes directly to the carb on the fuel pump end..(end opposite the one with hole in the cover). The larger line coming out of the fuel tank goes to the longer nipple on the purge/primer bulb. The other line coming off of the carburetor (on the end with the hole in the cover) goes to the shorter nipple on the purge/primer bulb. The purge bulb "pulls" air and old fuel out of the carb thus allowing fresh fuel to flow in from the fuel tank and then it "pushes" this mixture of air/old fuel back to the fuel tank.
Jul 16, 2010 | Craftsman Convertible 25cc. Gas Line...
On off on off on off
possible cause is the thermal fuse for the light bulb which is the back of the tv, next to the cooling fan.
Dec 29, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
My 83 year old dad wants to hook up a VCR to his television do you have inbstructions?Thanks
ok one normal coaxal lead in goes in to the back of the tv were the areal goes and into the vcr rf out put
the areal from the roof goes into the areail on the back of the vcr
Jul 04, 2008 | Panasonic NV-SJ205 VHS VCR
Royal wes50 surround sound wireless headphones Logo
Top Royal Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Royal Audio Player and Recorder Expert? Answer questions, earn points and help others
