Question about Apple MB293LL/A 32GB iPad Tablet with Wi-Fi - Gen 1
Need to reset passwods on ipad model#MB293LL - Apple MB293LL/A 32GB iPad Tablet with Wi-Fi - Gen 1
My sister forgot her Apple ID on her iPad and she's 55 and can't remember her password what to do?
Under this circumstance you may have to reset the iPad if you forget both Apple ID and its password.
To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your tablet. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad . In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
Mar 19, 2017 | Apple iPad Tablets & eReaders
Re set ipad mini
Generally speaking, you need the Apple ID to reset your iPad. iPad needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPad, you need to enter the Apple ID when your iPad reboots.
But if you have no Apple ID or passcode, you will have to reset your iPad without Apple ID. To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your iPad. The following steps will show you how to do that.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad. In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
Jan 01, 2017 | Apple Tablets & eReaders
Turrent downloaded for ipad
Michael, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Download Torrents on iPad iOS Without Jailbreak
How to Download Torrents on iPhone iPad or iPod Touch NO JAILBREAK iOS 9 9...
Download Torrents on iOS iPhone iPad and iPod Touch
Easy way to Download Torrents on iPad without Jailbreak
Jul 02, 2016 | Apple MB293LL/A 32GB iPad Tablet with...
How to move information from one program to anther on you iPad tablet
If you have a picture that you see in Safari that you'd like to save in the Photos app, tap and hold the image, then select "Add to Camera Roll". Let me know if that doesn't solve your issue.
Feb 24, 2014 | Apple MB293LL/A 32GB iPad Tablet with...
How do I download iOS 6.0 on my iPad first generation
you cannot!
on a 1.gen. pad it is impossible to install iOS6:
this model supports only iOS 5 !
- NO iOS 6/7/8
- the processor is too slow....
For the iPad first generation (A1219) before iOS 5 to update is only possible with connecting the device to iTunes on a computer. Plug it into your computer and open up itunes under devices click on your ipad and then click on check for update.
- but this model supports only iOS 5
download-ios-6-0-ipad-first-generation-ucocffsbdgqp14shduy2nfxr-3-0.jpg download-ios-6-0-ipad-first-generation-ucocffsbdgqp14shduy2nfxr-3-2.jpg download-ios-6-0-ipad-first-generation-ucocffsbdgqp14shduy2nfxr-3-9.jpg
Feb 04, 2014 | Apple MB293LL/A 32GB iPad Tablet with...
IOS 6 for iPad
on a 1.gen. pad it is impossible to install iOS6!
- NO iOS 6/7/8
- NO iOS 6/7/8 !
ios-6-ipad-ankdbq4aprjqdzyss1inbix3-4-0.jpg ios-6-ipad-ankdbq4aprjqdzyss1inbix3-4-2.jpg ios-6-ipad-ankdbq4aprjqdzyss1inbix3-4-5.jpg
Feb 02, 2014 | Apple MB293LL/A 32GB iPad Tablet with...
Not up dating iOS.6
- NO iOS 6/7/8
- NO iOS 6/7/8 !
not-up-dating-ios-6-ucocffsbdgqp14shduy2nfxr-3-0.jpg not-up-dating-ios-6-ucocffsbdgqp14shduy2nfxr-3-2.jpg not-up-dating-ios-6-ucocffsbdgqp14shduy2nfxr-3-5.jpg
Jan 30, 2014 | Apple MB293LL/A 32GB iPad Tablet with...
I need iOS 6.0 downloaded.
Firstly sync all your data. Sometimes updates wipe your data. Secondly, since iOS 7 has been introduced it will download the latest update available (the new software), iOS 7) if you are willing to update.
Now to update go to your settings and then go into "General". Under "About" there should be Software Update, Click on that it will take you to the information about it. Then click "Download and Install'. I also suggest you are charging it as this update can take hours and some minutes. It all depends on how long you havent updated the iPad or iPod.
Enjoy
Jan 21, 2014 | Apple MB293LL/A 32GB iPad Tablet with...
Download ios 6.0
- NO iOS 6/7/8 !
for all other models:
There are two ways to upgrade the iOS version of your iPhone, iPad, or iPod Touch - via connecting the device to iTunes on a computer
- or directly from within the device, but only since iOS 5, it is possible to upgrade the iOS version without the need to connect the iOS device to a computer (over-the-air update)
just go to: settings - general - software update
download-ios-6-0-dbkgqaf2olnzmm535x2pjf5h-2-0.jpg download-ios-6-0-dbkgqaf2olnzmm535x2pjf5h-2-2.jpg download-ios-6-0-dbkgqaf2olnzmm535x2pjf5h-2-5.jpg
Jan 08, 2014 | Apple MB293LL/A 32GB iPad Tablet with...
Who to copy files pc to ipad through itunes
Sync the device to the computer. Save the files and then you can look at then under what they are named
Jan 24, 2013 | Apple MB293LL/A 32GB iPad Tablet with...
Apple MB293LL/A 32GB iPad Tablet with Wi-Fi - Gen 1 Logo
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
Yoav Shilon
Yoav Shilon
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
