Question about Welch Allyn Spot Vital Signs Monitor
I get an e42 error code - Welch Allyn Spot Vital Signs Monitor
My zanussi washer is coming up with error code 40 anyone no what it is
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
Dado
Aug 27, 2015 | Zanussi Washing Machines
What does the error code e42 mean
  • You can go to google and question the make,model# and error code and get a quick response.
Aug 10, 2015 | Washing Machines
Error code E40 on a Electrolux Front Loader Washing Machine EWF1090 What does it mean and how can I fix it?
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensor faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Feb 24, 2015 | Electrolux Washing Machines
Error code E42
Error 42 indicates scanner failure. It is sometimes caused due to loose /
faulty scanner cable that connects scanner to motherboard.
***If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Feb 14, 2013 | Canon PIXMA MP150 All-In-One InkJet...
Error e42 22
Apr 24, 2011 ... E40 20 = Other hardware error. E42 22 = Scanner error. How to reset CANON WASTE INK COUNTER MP160/MP145 Before you reset the ... canonprintersink.com/error-code-printers-reset-canon-mp145-mp160.html canonprintersink.com/error-code-printers-reset-canon-mp145-mp160.html
have just checked this site and I am sure it will help you
Feb 20, 2012 | Canon Office Equipment & Supplies
What the solution for canon mp145 error e42 or how to solve the problem error e42 for canon mp145
Hi
This is neo . Welcome to Fixya . MP145 E42 is scanner error, it means there is a problem in the scanner, for errors like this can not be reset, try to check the lights scanernya, whether at the time of the printer on the lamp flame scanner or die, if death mean damaged, then check, scanner motor cable, ribbon scanner cable to the mainboard of the printer (unplug and plug it back), if still errors check the movement of stuttering .
Nov 06, 2010 | Computers & Internet
Canon printer MP160, I keep getting an error message E42. Nothing will reset. What does this mean?
E42 Scanner error
Sorry thats all I can tell you maybe some eles will gave you more
All Best
Jan 28, 2010 | Canon Office Equipment & Supplies
Error e42
It mean you have damaged scanner. Disassemble the printer then change flex cable, if problem still exist try to change scanner.
More clear about error code for Canon printer :
CANON MP Series Error Code
Oct 05, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Error code 30 - printer not activated on Cannon 210
E3-3 = Paper jam
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD over current error – USB
E37 17 = Abnormal motor driver error
Aug 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Welch Allyn Spot Vital Signs Monitor Logo
102 people viewed this question
Top Welch Allyn Medical Experts
Electro Med Services...
Are you a Welch Allyn Medical Expert? Answer questions, earn points and help others
