Question about Mitsubishi Office Equipment & Supplies
P93 printer error code EL - Mitsubishi Office Equipment & Supplies
Bizhub 350 manual de servicio codigo de error el c0500
In correct code for a Bizhub 350. What is the model # Bizhub Fuser errors start with 34, 37 ,38 for the Bizhub 200/350
May 11, 2013 | Minolta bizhub 200 Copier
We just bought Fargo HDP5000. on first installation now its bringing error code 97 and 99 which when we calibrated the printer the error 99 was solved. but the error 97 is still there. pls help
hola hermano tengo problema con mi impresora hdp 5000 cada vez que boy a imprimil me da un error 103 y 105 me dice en la pantalla del monitor de mi pc que el sensor no detecta el movimiento del cabezal
Apr 19, 2011 | Fargo HDP5000 Thermal Printer
Canon IR1510 error E000
there is a problem in the fixing assembly something to do with the thermoswitch if i am not mistaken without the full error code it is hard to say exactly what is wrong with it
Jun 10, 2010 | Canon imageRUNNER 2000 Copier
Sharp ar -m351 Error codes L4-30
sharp printer mx-m450n error code l4-02
Nov 24, 2009 | Sharp AR-M450N Copier
I have always error code 546 and 960
Error Code SC 546 is for fusing & SC 960 is for Current leakage, If u getting it regurally , change the thermistors for error code 546, & for error 960 change drum & charge roller.
Aug 16, 2009 | Ricoh Aficio 450 Copier
Erox dc 12 error 9-342
In Spanish
Quita la tapa de el drawer
Obseva la media lunita de el 2nd BTR Black & yellow Cheat el sw de la puerta Si no hace el intento de girar . Quita la tapa posterior y observa si gira el motor principal y el motor de el cilindro si no giran tienes un problema en la AC driver 5Volts o en los 24 volts verifica tambien los fuses de la PWB de interconexion y de la Ac driver suerte
Nov 12, 2008 | Xerox DocuColor 12 Printer
Getting error 0xc18a0206
Aquí es el contenido de la charla, espero que te ayuda también! Christina es la persona de soporte técnico.
Cristina: Vamos a realizar algunos pasos para aislar el problema y encontrar una solución para ello.
Christina: Por favor siga los siguientes pasos y que me haga saber el mensaje que se mostrará en la impresora.
Christina: A. - Mantenga pulsado el "*" tecla.
B. - Presione la tecla "#" y suelte ambas teclas.
La pantalla debe decir "Intro Especial clave Combo"
C. - Presione y suelte en la secuencia de "1", "2" y "3" botones.
CustomerName: ok
CustomerName: pantalla dice "apoyar" R0631M
Christina: Fine.
Christina: 2. Oprima y suelte el botón de flecha derecha hasta que la pantalla dice "Menú de configuración del sistema".
Christina: 3. Oprima y suelte el botón "Aceptar".
Christina: 4. La pantalla debe decir "estado de error de hardware". Si no existe ya, tecla de flecha a "estado de error de hardware",
Christina: 5. Oprima y suelte el botón "Aceptar".
Christina: 6. La pantalla debe decir "estado de error de hardware: Despejado. Pulse OK para borrar ".
CustomerName: yup
Christina: 7. Oprima y suelte el botón "Aceptar". Mensaje a los cambios "estado de error de hardware Resueltos. Pulse Cancelar para continuar ".
CustomerName: ok
Christina: 8. Pulse y suelte el botón "Cancelar" tantas veces como sea necesario, de modo que, o bien el "Bienvenido a Photosmart Express" aparece la pantalla, o, el "fallo del sistema de tinta" aparece la pantalla. POR FAVOR, NO intente imprimir en esta etapa.
CustomerName: ok
Christina: 9. Utilizando el botón de encendido, apague la unidad y desenchufe el cable de alimentación de la parte posterior de la impresora y la pared.
CustomerName: hacer
Christina: Fine.
Christina: 10. Espere 30 segundos para obtener el poder de vertido y, a continuación, enchufe el cable en la toma de corriente y, a continuación, en la parte posterior de la impresora
CustomerName: hacer
Christina: 11. Encender la unidad. La impresora puede mostrar mensaje "BOTóN PARA PODER UTILIZAR LA IMPRESORA SHUTDOWN" seguido de "Pulse OK para continuar". Pulse Aceptar. La impresora comenzará la "TEMNE UNA TINTA proceso de inicialización". Permitir que este proceso para completar y no interrumpir. Una vez que el proceso de inicialización se ha completado, la impresora imprimirá una página de diagnóstico.
CustomerName: hizo una buncha ruido, y no imprimir una página de diagnóstico
Christina: Bueno.
Christina: ¿Es todavía el mensaje de error que se muestra en la impresora?
CustomerName: No
Christina: Bueno.
CustomerName: debo intentar imprimir algo?
Cristina: Vamos a imprimir una página de prueba libre, para comprobar la funcionalidad de la impresora.
Christina: Pulse sobre el menú de configuración "todo en uno" luego desplazarse utilizando la tecla de flecha y seleccione la opción Imprimir a continuación, seleccione Informe de Autoevaluación Informe de ensayo.
Oct 22, 2008 | HP Photosmart C5180 All-In-One InkJet...
Error code E5 on LCD Canon Pixma MP160
Yo tambien tengo una canon pixma mp160 y me da el mismo error por culpa de los cartuchos. La solucion simple y llanamente pasaría por comprar cartuchos nuevos originales, pero a veces te sigue dando el mismo problema incluso con ellos. Asi pues, lo que yo recomendaría es no comprar esta impresora.
Ah! se me olvidaba, que piden que escriba en ingles, porque dicen que "esto es america", no amigos, esto no es america, esto es internet. El mundo globalizado, irse acostumbrando a usar mas de un idioma.
Jun 27, 2008 | Canon PIXMA MP160 All-In-One InkJet...
How to reset the ink level monitor on Canon Prixma MP 160
Disconnect the printer's outlet
Hold the Botton of power while connecting to the outlet
Holding down the power button pressed twice the reset button (red circle with a triangle)
Release the power button
The printer takes about 10 seconds into the show vaor numeroco zero.
Pressing + to the value moves from 0 to 1.
When this value to 1, press the button that is on par with reset, this will light up two lamps
One is that of plain papaer and the other of photo paper, at this point is put paper into the printer
Pressing the power button once or twice (it does not matter), the printer will print a proof sheet
When you print this sheet the value in the display returns to zero, leaving it well
Open scan cover (to remove the cartridges but was not removed), with the lid open faith disconnect the power to printer
Remove the cartridge, close the lid and turn on the printer.
Re-positioned and Refill cartridges in the printer and READY.
Mar 12, 2008 | Canon PIXMA MP160 All-In-One InkJet...
51 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
