Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Where is the water filter for Refrigerator model # 57562792
2 Suggested Answers
  • 401 Answers
SOURCE: Water dripping out of water dispenser tube
SOUND LIKE YOU HAVE A BAD INTAKE VALVE. IF THE WATER DRIPS ALL THE TIME.
Posted on Jan 12, 2010
Replaced water filter on a Maytag refrigerator it uses whirlpool filter. when filter is replaced and you try to use the water dispenser you get a loud grinding noise from the filter, how do you fix this?
I need to know which model you have, because i would explain the issue you have better. I thin it would be a MSD model and it could mean a board collision in the touch panel to the dispenser.
Please let me know your model so I can help you further.
Good Luck
Sep 01, 2013 | Whirlpool Refrigerator Water Filter
Cannot locate water filter for my kenmore Refridgerator 106-57562792
Yes the filter is only available on some models. This is noted in the manual next to the part description: Part 14 Water Filter (on some models).
The entire set of parts lists (including a replacement grill plate, if you want it) is available from Sears Parts Direct: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657562792/0582/0165000?pathTaken=&prst=0&shdMod=10657562792 . The grill plate is part 13 on the cabinet diagram.
I hope this helps.
Sep 04, 2012 | Refrigerators
Were is the water filter on a amana sxde 526 m does it have one
I looked up your Model with both P#'s. Sadly no water filters for your Refrigerator. Amana only has a few models with water filters.
Sep 04, 2012 | Amana 22.6 cu. ft. Side-By-Side...
Red light on to replace water filter, how to do this?
Knowing just who made your Kenmore refrigerator may some day be important because Kenmore does not make the brands they sell. I am going to try to get you as many different ways the water filter can be changed as I can but if you can you locate the model number of your Kenmore it may make things much easier should you need parts or a manual some day. The number should look like this 521.345678 and located around the inside of the fresh food section door.
Here nis what I have found on different models and water filters from Whirlpool How to Replace In-Grille Refrigerator Water Filter - Push Button
How to Change the Water Filter in Your Refrigerator
Whirlpool Part UKF7003
How to Change a Kitchen Aid Refrigerator Water Filter
Read more:
If by chance you are able to find your model number that looks like the 513.235647 I mentioned before this will solve just what instructions you need or you can post a photo here or swend one to my email appliancepartsse (@) yahoo.com and I will be glad to help you get a manual and instructions for changing your water filter, Thanks Sea Breeze
How to Replace Interior Refrigerator (Filter1) Water Filter
Jun 25, 2012 | Kenmore Side by Side Refrigerator
Ice maker (Kenmore model #57562792). When dispensing water into the tray the water will freeze in the shoot. Resently the water oveflowed out of the shoot freezing the water. It is like the sensor value...
Hi and thanks for choosing FixYa I am Kelly.
Ot took me a bit to sort out your model number started with 106 for a complete model number of
106.57562792.
You already more or less stated what the remedy is. in this starement:
It is like the sensor value does not know when to stop sending water to the tray
What happens during the life of refrigerator is the inlet water valve fails. This caused the ice in the water fill tube because it was a very slow drip so the wter froze in the tube. It also causes the ice tray to overfill because it is allowing water to bypass when it is supposed to be shut off. (Common problem after unit is 4 - 7 years old)
Your inlet water valve needs to be replaced PN: 2182106
Net search: 2182106
http://www.google.com/search?q=2182106&rls=com.microsoft:en-ph&oe=UTF-8&startIndex=&startPage=1&um=1&ie=UTF-8&tbo=u&tbm=shop&source=og&sa=N&hl=en&tab=wf
Sears parts direct lists it under your model number for $70.92. As you can see from the net search... you can get them MUCH cheaper.
When you change this inlet water valve... save yourself all the headaches... Change ONE line at a time and One connector at a time. Hook up the main water supply LAST.
This will fix your current problem.
Thanks for choosing FixYa,
Kelly
Sep 03, 2011 | Kenmore Side by Side Refrigerator
Jenn-Air Refrigerator JS42SEDBDA Model 12606032GJ was in house when I brought house. No user manual. Does this model have a water filter? The refrigerator has the words water filter,and underneath that...
Remove the compressor cover to locate the filter.
www.appliancepartspros.com has the filter.
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-refrigerator-water-filter--puri-clean--item-number-ap4343710.aspx
Aug 20, 2011 | Jenn-Air JS42SEDBDA Stainless Steel Side...
Jan 12, 2010 | Kenmore Refrigerators
Water from Ge profile refrigerator tastes bad so does ice where can I find the filter? Model #TFH30PRT
The water filter for this refrigerator is optional. The GE part number is: WR97X0214, or one of the box stores also carries a universal filter. Just make sure it for a ¼ inch line. The water filter is located on the back side of your refrigerator, and will have to be pulled out from the wall. Use caution not to break the water line when pulling/rolling it out.
Apr 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator Model FR23W3aw0 Frigidaire
cant bring up that model # there in the refrigertor side top right... in rouund like the fliter, plastic case most filters usually just turn counter clockwise to come off
Sep 03, 2007 | Sub-Zero 680 / S
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
41 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
